Guest anguscanplay Posted May 19, 2008 Share Posted May 19, 2008 ... any ideas roughly how much it'd cost to get someone to fit new battery etc? Cash is tight due to house move! about the same as the cheapy wireless would cost if I did it, but you`ll still have the better system rather than a cheap one Link to comment Share on other sites More sharing options...
Chorlton Posted May 19, 2008 Share Posted May 19, 2008 Is it? Fair point - I have no idea!In two minds as what to do but need to do something... Either get someone round to take out 9200 then replace with a cheapy wireless by myself or get someone round to try and find fault with 9200... any ideas roughly how much it'd cost to get someone to fit new battery etc? Cash is tight due to house move! roughly, Link to comment Share on other sites More sharing options...
GaryPod Posted May 20, 2008 Author Share Posted May 20, 2008 roughly, Link to comment Share on other sites More sharing options...
arfur mo Posted May 20, 2008 Share Posted May 20, 2008 Ok thanks guys,BTW am loving the Chorlton avatar! i think he was 'surprised' (pleasantly i'd hope) while standing at the sink if you replace your existing 9200 panel the fault may not actualy be with it, like i say 1st suspect is always the battery. if you concider this is only a 2 zone panel upgrading to a later unit will allow more detection and/or splitting up that you already have, also better programming would be available. i suggest a good 'half way' for you is to have a Gardtec G490 panel installed as direct replacement, then should problems occur you will know where to look. if you subsequently require radio them the G490 can be fitted with a receiver and radio detection so you have the best of both worlds with an onboard voice dialer thrown in, so your not wasting any money on capital outlay. imo and that of many others in here is Gartec Radio gear is amongst the best (if not the very best) kit available. post your district, i'm sure a local installer will contact you, but as advised get guestimate before engaging anyone - membership of this forum is sort after but is not akin to a membership to heaven, hopefully selecting from the membership should be less risky than using a pin in yellow pages. Regs Alan regs alan If you think education is difficult, try being stupid!!!! Link to comment Share on other sites More sharing options...
GaryPod Posted May 27, 2008 Author Share Posted May 27, 2008 post your district, i'm sure a local installer will contact you, but as advised get guestimate before engaging anyone - membership of this forum is sort after but is not akin to a membership to heaven, hopefully selecting from the membership should be less risky than using a pin in yellow pages. Am 3miles from Nottingham center so will go have a look on the installers list section... Link to comment Share on other sites More sharing options...
GaryPod Posted May 29, 2008 Author Share Posted May 29, 2008 Hi all, back again. Sorry to go on... just a thought. I did a bell test on the system and it didn't go off, the internal alarm / sounder / buzzer (whatever it's called!) on the control went off but not the external bell. Does this mean I can probably cut / disconnect the wires to the external bell box without it going off? I realise you guys can't give out disabling info etc, am hoping it's ok to ask this! I've been quoted Link to comment Share on other sites More sharing options...
james.wilson Posted May 29, 2008 Share Posted May 29, 2008 I would assume your securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
billythebellbox Posted May 29, 2008 Share Posted May 29, 2008 I've been quoted De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da Link to comment Share on other sites More sharing options...
amateurandy Posted May 29, 2008 Share Posted May 29, 2008 how's does that rate compare to getting an IT man on site? Depends. Similar. Link to comment Share on other sites More sharing options...
