Securit 700l Problem
imroberts
I have recently disconnected and reconnected a couple of sensors due to decorating and have since been unable to set my alarm.
As soon as I start to enter the code the control panel starts beeping, and will continue beeping until I press # and wait a few seconds.
I'm guessing this has locked me out due to something I've done wrong... can anyone tell me why or how I can resolve this?
Guest anguscanplay
Everything is back as it was, still the same problem :(
obviously not back as was then - do you have a test meter ?
billy - why do you have a Police record ....
...as a siggy
All the wiring is back as it was. The alarm isn't operating though. It doesn't even set off the tamper alarm if things are tampered with, it's as if it has switched off all monitoring.
And yes, I have a test meter :)
All the wiring is back as it was. The alarm isn't operating though. It doesn't even set off the tamper alarm if things are tampered with, it's as if it has switched off all monitoring.And yes, I have a test meter :)
endstation?
its all I want to say to you ;)
De Do Do Do, De Da Da Da. De Do Do Do, De Da Da Da
try pressing your code and * - it probably just needs a reset (code + star (*) = reset.)
Assuming that your TAMP (tamper) light is,nt still illiminated that will clear the system.
paul
THE BLACK KNIGHT
"Any comments / opinions posted are my opinion only and do not represent those of my employer or Company."
