charlesking Posted December 21, 2007 Share Posted December 21, 2007 does anyone know how to put the minerva mx2 panel into one man test (if it has one that is) Quote Link to comment Share on other sites More sharing options...
Guest Cerberus NI Posted December 21, 2007 Share Posted December 21, 2007 does anyone know how to put the minerva mx2 panel into one man test (if it has one that is) That'll be the conventional one then??It involves pressing a small button located on the pcb - are you an engineer?? Quote Link to comment Share on other sites More sharing options...
luggsey Posted December 21, 2007 Share Posted December 21, 2007 That'll be the conventional one then??It involves pressing a small button located on the pcb - are you an engineer?? MX2 is an analogue? Quote ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
Guest Cerberus NI Posted December 21, 2007 Share Posted December 21, 2007 MX2 is an analogue? Sorry - slight brain melt moment!Was thinking of the MX-C (where the C refers to conventional!) Quote Link to comment Share on other sites More sharing options...
luggsey Posted December 21, 2007 Share Posted December 21, 2007 Sorry - slight brain melt moment!Was thinking of the MX-C (where the C refers to conventional!) I too have these moments! To much canned smoke in my yoof! Quote ----------------------------------------------------------------------------------------------------------------------------------- Life is like a box of chocolates, some bugger always gets the nice ones! My Amateur Radio Forum Link to comment Share on other sites More sharing options...
sparky999 Posted December 21, 2007 Share Posted December 21, 2007 does anyone know how to put the minerva mx2 panel into one man test (if it has one that is) The fast access code for walk test is 71 Pete Quote Peter Robinson Freelance M:07889038650 Link to comment Share on other sites More sharing options...
F C E Posted December 23, 2007 Share Posted December 23, 2007 sorry sparky999 your thinking of the minerva 80 the mx2 doesnt use fast access codes if memory serves, should be under user 02 code 2222 if not then would need to be programmed from engineer level Quote All comments in this post are my own views and do not necessarily reflect the views of my employer Link to comment Share on other sites More sharing options...
sparky999 Posted December 23, 2007 Share Posted December 23, 2007 Page 7 of the MX Service Engineer manual Pete MXServiceEngineerManual.pdf Quote Peter Robinson Freelance M:07889038650 Link to comment Share on other sites More sharing options...
F C E Posted December 23, 2007 Share Posted December 23, 2007 i humbly stand corrected Quote All comments in this post are my own views and do not necessarily reflect the views of my employer Link to comment Share on other sites More sharing options...
fattypotter Posted May 20, 2009 Share Posted May 20, 2009 use o1 code 1234 then menu number 7. this is service menu, then follow the on screen menu ,enter the option for one man test all zones. this will only allow you to end when clear of fire signals. this menu is ended by pressing f5. hope this helps eddy:beer: Quote Link to comment Share on other sites More sharing options...
