Guest davet Posted November 26, 2006 Share Posted November 26, 2006 Screw fix heavy duty contact 3 wire I have purchased on of these for my garage door it has 3 wires blue yellow and black has anyone got some information on how to wire it up currently I have blue and yellow connected as a zone but it shows an open circuit so I am now assuming the black wire does come into play but where does it go? Thanks Dave. Link to comment Share on other sites More sharing options...
camerabloke Posted November 26, 2006 Share Posted November 26, 2006 continuity test between the pairs in turn against magnet untill you get short, then remove magnet and see if short clears Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
antinode Posted November 26, 2006 Share Posted November 26, 2006 It should have come with instructions on how to wire the unit. If not you will need to use a multimeter or some other method of continuity testing to identify the normaly closed pair (ie you get a closed circuit with the magnet in place and an open circuit with the magnet removed). Try metering between black and blue and black and yellow. Trade Member Link to comment Share on other sites More sharing options...
Guest Alarm Guard Posted November 26, 2006 Share Posted November 26, 2006 Could it be common, Normally Open and Normally Closed? Link to comment Share on other sites More sharing options...
stewymac Posted November 26, 2006 Share Posted November 26, 2006 Could it be common, Normally Open and Normally Closed? agree 3 wires..its got to be c/no/nc..tho what use a no contact has on an inruder alarm beats me,sounds like one of those contacts connected to a heating system you see in factorys on the roller door.. Link to comment Share on other sites More sharing options...
Guest davet Posted November 26, 2006 Share Posted November 26, 2006 Sounds like theres a red wire missing? or its EOL? I think the latter unlikely DIY panels are not usually overcomplicated.Pete AHa found the bloody red wire about 20mm down the sheath thanks i now I assume the red is the power supply and the black is the earth thanks for your help. Regards Dave. Link to comment Share on other sites More sharing options...
james.wilson Posted November 26, 2006 Share Posted November 26, 2006 no no no red and yellow will be your alarm pair and black and blue is tamper dont put any power on it it you might kill it!!! securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
stewymac Posted November 26, 2006 Share Posted November 26, 2006 AHa found the bloody red wire about 20mm down the sheath thanks i now I assume the red is the power supply and the black is the earth thanks for your help.Regards Dave. 12v contacts...en regs have gone too far.. AHa alan partridge alarms ltd... Link to comment Share on other sites More sharing options...
Guest davet Posted November 26, 2006 Share Posted November 26, 2006 no no nored and yellow will be your alarm pair and black and blue is tamper dont put any power on it it you might kill it!!! Thanks Link to comment Share on other sites More sharing options...
stewymac Posted November 26, 2006 Share Posted November 26, 2006 i blame b&q... Link to comment Share on other sites More sharing options...
camerabloke Posted November 26, 2006 Share Posted November 26, 2006 or screwfix Eucam Security Systems 0845 4630 746 www.eucam.co.uk Link to comment Share on other sites More sharing options...
Guest davet Posted November 26, 2006 Share Posted November 26, 2006 Yep that works well connect the 12vdc to those two, and everytime a burglar breaks in and closes the door your alarm will go off and not even you will be able stop it (youll need an endless supply of fuses though) Yes now sorted thanks for your help and I bet I made you smile Link to comment Share on other sites More sharing options...
Guest Alarm Guard Posted November 27, 2006 Share Posted November 27, 2006 Yes now sorted thanks for your help and I bet I made you smile You certainly did! Forget doing the alarm. You could script write for Peter Kay. Link to comment Share on other sites More sharing options...
