Network Recording Device For Ip Cameras
Guest paddy
  • Replies 22
Hi
Are there any 4 Channel Recorders on the market that can be connected directly to IP cameras using RJ45 connectiors.
Thanks in advance
Paddy
It's a bit late for me to get my brain in gear, but I vaguely recall that March Networks may have a 4 channel unit that fits the bill. http://www.doktorjon.com/manufacturers/M/march1.html
I know that a few other manufacturers have launched some interesting products in the last few weeks; JVC for example are introducing a standalone with Milestone Systems software on board, and Wavelet have also launched a new model that allows both analogue and IP camera connection, but I think they are probably 9 channel units.
If you're interested, post back and I'll dig out some links.
Quadrox network video recorders accept direct IP inputs from a range of IP cameras (Panasonic/Axis/Sony etc.). Several other manufacturers support a mix of analog and IP inputs. Most manufacturers offer a single RJ45 input, multiple cameras are input via a standard hub. Inputs are not limited like traditional DVRs with BNC connectors. The limitation on IP camera inputs is defined by the processing power of the recorder (often max of around 10 - although some manufacturers state up up 32).
Link:
http://www.webcctv.com/start.asp?main=webcctv_nvr
Paul Main
ClearView Communications Ltd
Robjohns Road Chelmsford
Essex CM1 3AG
Telephone: 01245 214104
Fax: 01245 214101
paul.main@clearview-communications.com
www.clearview-communications.com
Personally I don't see IP camera support as stable enough yet to rely on long-term. Admittedly this is mainly because the last IP cam implementation I saw on our kit wasn't too hot, but overall it doesn't seem to really hit the right mark...
psumner@dmicros.com
Manufacturer
... multiple cameras are input via a standard hub.
here an it man would use something else than hub..
professional software can easily record at rates of 1000ips. divide that across how many cameras and ips per camera you wish but i think it exceeds 32 anyway..?
Georg, im curious 1000 fps thats huge, any links im vurious. Didnt know Big blue had been made into a dvr
seriously im curious to see the hardware req for that fps
software database can achieve a throughput of 1000 ips. below is a hw needed for approx 30 video sources.
Xeon Dual Processor with each 3.2 GHZ Processor speed
RAM 4 GB
Enough archiving space for images, system with RAID 1
Network Card: 100/1000 Mbps
OS: Windows Server 2003 or Linux Suse from 9.6 or higher
OS: Windows XP Pro
not too silly i think..
:question:
