binthere Posted August 22, 2006 Share Posted August 22, 2006 Hi to all, I was recently called to an address which seemed familiar, when i got there i remembered that it was my first installation as an engineer. The alarm panel was a Metal ADE Logic 4 ( for the newer engineers, yes they used to make them from metal......) To my surprise it was still going strong.. no problems at all, just needed the back up battery changing. No matter how much i tried, the couple refused to upgrade, all this new fangled technology is not for them... I just wondered what is the other installers first panels were??? Great forum love reading the topics ... Very interesting, I wish I was that young the first panel I fitted was Rely a Bell panel in 1970 the actual panel was wired with anti tamper wire, all windows and door's were wired the 'old way' it was really hard work the back up battery was an Ever Ready type battery, the alarm was connected to a TYPE of dialling machine that had a specially made record placed on a turrntable which sent a message to the Police, there was also another type of Police calling device that went direct to the local 24 hour manned Police Station where we had access to test, at the Police Station there was banks of switches that activated when signalled the switch relay went down an an audible signal was heard the Police Officer then checked the numbered switch and dispatched a Police car. Believe me this is true even I often wonder if all that really did happen after what we have now days. hi binthere, i'm not sure your memory serves you to well mate, especially about the 12 volt battery. rely-a-bell was 5 qs flags in the panel and 3 x 'O' cells end of line. Burgots had an EverReady HP1 as standby as it was a 12 volt system. the PIU (Police Indicator Unit) was fitted to the local police station. a high security 'balanced' version came out later which had 8 channels and had to be 'tuned' both ends - nightmare for service in electrical storms if lightning bolt hit the manhole outside the main police station - which it did 3 times over one easter weekend at Southend - and i was on call. the '999' you speak of which were 12 volt battery operated was called an 'RG' or 'RE' , one version had line fault sensing, a good clump on the catch side of the case used to send the arm across the record and cancel the call servicing was a bit 'brutal' in those days B) . regs alan Hi Alan I will not say who I am for security reason's, (I changed to a Govt Dept in the 70's)but I believe we do know each other especially as you worked in Southend nick, the banks of about 10 switches in each bank they were were behind the front office had 3 set positions up middle or down as you say, they were a pain in the Harris I must admit it was a long time ago and my memory is not 100% tend to be clear about good things to remember but bad things it is easier to forget. Do you remeber Tom Buckley Binthere Quote Link to comment Share on other sites More sharing options...
binthere Posted August 22, 2006 Share Posted August 22, 2006 Right, here goes. One of oldest panels I worked on when I started with Moderns in 1986 was a Brocks Analyzer. It had EOL batteries in the form of flag cells with 6v lantern batts to power the panel. They sometimes had a reel to reel tape player attached, a 999 unit which had to be rewound by hand to reset. Until someone told me about a link between two terminals which would rewind it under it's own power. If the EOLs went down and you'd run out of flag cells, you could put a 6v on the end to get you out of trouble. For about 10 minutes when it would FA as you were driving away. The oldest had to be the S type 1. A keyswitch and toggle switch on a block with the panel containing batts mounted higher up the wall. Lacking a buzzer, this beauty would ring both internal and external bells on setting and unsetting. I'll bet the neighbours were impressed. I remember a 74 panel connected to a boxed turntable that had to be reset by pressing a button on the deck and cueing up the record. The start of my DJing career. Took this out recently, and it stil worked thats the type I refered to with the ever ready lantern battery I am truly gobsmacked to see the beast, who the hell was it signalling to ! binthere Quote Link to comment Share on other sites More sharing options...
DAVID HINGE Posted September 13, 2006 Share Posted September 13, 2006 :!: Sorry but I can not let this one go!!! The first panel we used was home made with BIG RED LIGHTS on it! and a great big key and was very very big, and the engineer that made it up rushed off into the trraffic and said to the copper on point duty ' Harry What do you think of this then?' 'Why thats bloody big and what a bonny colour I like it!'.................. That night we had an advert in the local paper front page top banner 'POLICE APROVED' !!!!!! sorry but it was fourty odd years ago and we still used drawing pins for door contacts! Oh God! hurray for the good old days.......with that I shall creep away back into the clouds of retirement) David Hinge Quote Link to comment Share on other sites More sharing options...
ee8mjb Posted September 13, 2006 Share Posted September 13, 2006 The oldest panel we look after was 32 years old this week (yep 1 customer since new, fully functional, full drawings marked up with cable routes and junction boxes). It's weird working on stuff that was fitted before I was born, and the bloke who fitted it is probably long gone (customer remembers he retired the year after is was fitted)... Matt Quote Link to comment Share on other sites More sharing options...
AndyAAI Posted October 23, 2011 Share Posted October 23, 2011 Ok. Here goes. I was born in 1968 so I will give you my odest panel info. First control unt I ever installed was an A&G R52E keyswich split zone control unit. Then I moved onto a Castle CX1001. To this day, my favourite control unit was a Castle ZX1250 expandable control unit. When I left school I joined Chubb Alarms as an apprentice, working with Gordon Taylor in West London. At that time we were fitting Guardall CA 202 and CA 210 control units. That said, I used to work on CA 45, CA3, CA6 (bank control units - I was trained as a bank engineer ) CA5 and CA10 control unis with the odd CA100 and CA104. I don't that any of these panes still exist anywhere.. Comared with the A&G, Bon Autoation, Castle, Munford and White, Radiovisor Monive Panel (remember them?) and the Franken Systems panels all the Chubb panels were years ahead of there time. I had the most fantastic Training at Chubb Alarms and owe an awful lot to Godon Taylor, whom I am sill in regular contact with. He was a Burgot engineer. He taught me how to make tube and batten frames, lace wiring And how to foil windows using lead non self adhesive foil. Happy.....no Very Happy Days. Andy I remember the 'lock block and coffin' Rely-a-Bell control unis and the RG Grams (999 machines). We were fitting Internet directly line signalling years before the WWW had ever been invented. Over the years, I have been into loads of Central Stations. To my mid, the best Central Station I ever went to was at Clifton Street. It was over two floors, with a basement and ground floor. Quote Link to comment Share on other sites More sharing options...
Wyatthaplo Posted October 30, 2011 Share Posted October 30, 2011 I think my first install was a 9800+, still a bit of a youngster myself Quote Work Website: http://www.welch-group.co.uk/ Personal Blog: http://wyatthaplo.blogspot.com/ Link to comment Share on other sites More sharing options...
Hawaii Posted October 30, 2011 Share Posted October 30, 2011 Ok. Here goes. I was born in 1968 so I will give you my odest panel info. First control unt I ever installed was an A&G R52E keyswich split zone control unit. Then I moved onto a Castle CX1001. To this day, my favourite control unit was a Castle ZX1250 expandable control unit. When I left school I joined Chubb Alarms as an apprentice, working with Gordon Taylor in West London. At that time we were fitting Guardall CA 202 and CA 210 control units. That said, I used to work on CA 45, CA3, CA6 (bank control units - I was trained as a bank engineer ) CA5 and CA10 control unis with the odd CA100 and CA104. I don't that any of these panes still exist anywhere.. Comared with the A&G, Bon Autoation, Castle, Munford and White, Radiovisor Monive Panel (remember them?) and the Franken Systems panels all the Chubb panels were years ahead of there time. I had the most fantastic Training at Chubb Alarms and owe an awful lot to Godon Taylor, whom I am sill in regular contact with. He was a Burgot engineer. He taught me how to make tube and batten frames, lace wiring And how to foil windows using lead non self adhesive foil. Happy.....no Very Happy Days. Andy I remember the 'lock block and coffin' Rely-a-Bell control unis and the RG Grams (999 machines). We were fitting Internet directly line signalling years before the WWW had ever been invented. Over the years, I have been into loads of Central Stations. To my mid, the best Central Station I ever went to was at Clifton Street. It was over two floors, with a basement and ground floor. I remember the Radiovisor Monive panels we used them up till 1982 when we sold the company to Landers. We replaced one around 2000 which was made of wood, so it was pre BS 4737 1971, could have been made the year you were born. I kept it until last year when I had to get rid of lot of unused stuff as I retired to Menorca and the villas here do not have lofts to store old junk. Quote Link to comment Share on other sites More sharing options...
9651 Posted October 30, 2011 Share Posted October 30, 2011 We've still got a load of Logic 4's and old Bentleys out there under maintenance, got a REALLY old ADE panel in our stores, boss wont let it go, cream metal cased thing with a KS, i'll have to grab a pic! First system I installed myself was probably an Optima! Quote Link to comment Share on other sites More sharing options...
Able Alarm Posted December 5, 2011 Share Posted December 5, 2011 My first install was a diy key operated metal boxed 1 zone i bought from my elder sisters mail order catalogue when i was 16 years old. I fitted it and got paid cash, I thought this is great at the time but thirty or so years later i now cant shack off this abit. Then went onto A & G rs panels, Hilcare multizone expander with all the switches, Securit and the first Scantronic 9100 plastic 4 zone microprocessor panel for under £20. Reading this topic i have being reminded about just how old i am and how young most of you lot are. Quote AbleAlarmMan Able Alarm Ltd Link to comment Share on other sites More sharing options...
NowItsBroken Posted December 11, 2011 Share Posted December 11, 2011 Omicron 3000 :/ installation & user manual was like 2 pages. No programming as such and only a handful of unsupervised zones. Used to eat batteries from memory. That was the wired option and for wireless we fitted micromark. When I think back it was total **** and about as secure as a paper bag. Now I feel old Quote Link to comment Share on other sites More sharing options...
MrHappy Posted December 11, 2011 Share Posted December 11, 2011 and the first Scantronic 9100 plastic 4 zone microprocessor panel for under £20. can't recall anything in plastic before the 9450 ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
frenchman Posted December 11, 2011 Share Posted December 11, 2011 Key operated metal cased Cerberus-guinard, back home in 1999. Quote Link to comment Share on other sites More sharing options...
magpye Posted December 12, 2011 Share Posted December 12, 2011 YTA panels - c.1972/3 Quote Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
Able Alarm Posted December 13, 2011 Share Posted December 13, 2011 The plastic £20 Scantronic Panel went under the name Equizer and was sold by Gardiner (per ADI) Quote AbleAlarmMan Able Alarm Ltd Link to comment Share on other sites More sharing options...
shuban Posted December 18, 2011 Share Posted December 18, 2011 But I don't remember my 1st installation. Quote Body Armour Link to comment Share on other sites More sharing options...
MrHappy Posted December 18, 2011 Share Posted December 18, 2011 The plastic £20 Scantronic Panel went under the name Equizer and was sold by Gardiner (per ADI) no still never heard of it, rep pointfor 1st to produce a piccy ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Able Alarm Posted December 18, 2011 Share Posted December 18, 2011 no still never heard of it, rep pointfor 1st to produce a piccy ? Sorry only got a copy of the instructions now Equaliser 3 White plactic key operated box approx 12"w 8"h 3"d How do i upload a copy of the instructions Quote AbleAlarmMan Able Alarm Ltd Link to comment Share on other sites More sharing options...
MrHappy Posted December 18, 2011 Share Posted December 18, 2011 Click more reply option & attach file (when posting) Or click downloads tab & upload button (think these are still mod preview) Quote Mr Veritas God Link to comment Share on other sites More sharing options...
shuban Posted December 31, 2011 Share Posted December 31, 2011 But I don't remember what was my first panel. Quote Body Armour Link to comment Share on other sites More sharing options...
Able Alarm Posted January 10, 2012 Share Posted January 10, 2012 Please can anyone identify this and if so are there any manuals available? Quote AbleAlarmMan Able Alarm Ltd Link to comment Share on other sites More sharing options...
MrHappy Posted January 11, 2012 Share Posted January 11, 2012 rs40 ? (or some other regal safe product) Quote Mr Veritas God Link to comment Share on other sites More sharing options...
magpye Posted January 11, 2012 Share Posted January 11, 2012 Acorn control panels made in Cornwall - 1970/1 Both battery only and mains operated boxes Ramic, same era. Quote Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
bagpuss_24 Posted June 12, 2014 Share Posted June 12, 2014 I missed all this "chat" by about 3 years......... Being a bit nostalgic for old kit, I'd thought I'd add my bit.  I started working at Thorn Security in April 1994, (previously training as an electrician). My first "panel" there was an old AFA 'G-Type'- a hammered blue metal box with GPO 3000 relays, a meter, lamp, switch, keyswitch and a setting push on the front. This thing could be upgraded to 6 "circuits"- though onl4 4 were used. Above that was a hammered Blue AFA "drum" bell box, with 5 x R40 flag batteries, and a couple of relays. Out side was two of the Red equivalents, with yet more flag cells, and each has a plastic resin sealed module inside, where your panel end batteries, bell box batteries and bell would be terminated. Perhaps a very early form on SCB.All the doors were kick laced, had contacts fitted, windows were batterned/laced.Apart from the replacement of the circuit batteries, this system didn't give any problems.The next system I saw, was 1976 equivalent- this thing was the size of a suitcase, had the batteries, bell and a GPO approved lines unit in iside too- and was about 10 circuits.Other odd AFA ones around (and Thorn literally had 100s of the systems still on the books in our patch)- was a single zone one, a small box with a black knob, keyswitch and lamp.This was the most common intallation in shops. Usually fitted with shunt locks on the doors.I still have the circuits for them- not that there's much to them; but none the less, it's how they did things "back then".  My workshop still has a fully functional (though slightly modified) AFA system running, complete with bell boxes.The system was modified (by myself) to operate as a closed loop- using a Backup battery and PSU.I'd have to sell my kids, and remortgage the house if I was to keep replacing the Flag Cells.......  Anyone have any pics of any old systems knocking about? I'll get some photos of the AFA panel on my workshop. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted June 12, 2014 Share Posted June 12, 2014 Anyone have any pics of any old systems knocking about?  an old A&G panel came in last week, but I would assume its way too modern... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
bagpuss_24 Posted June 16, 2014 Share Posted June 16, 2014 When you say "too modern"; does that mean it's less then 40 years old? ;-) Don't think I've ever come across an A&G. Â I'd be intrested to see what the likes of "Rely a Bell" and "Clarion Equipment" were fitting in the 1930s...... Â I think the science musem in London has a first prototype mechanical Intruder Alarm from the 1800s, as well as a turntable auto dialler. Quote Link to comment Share on other sites More sharing options...
