Guest FireFocks2k Posted July 8, 2006 Share Posted July 8, 2006 Hi, I am wondering if anyone out there can help. My father in law is putting in an alarm system after being broken in to while on holiday, Yeah - I know- same old, same old...... Anyway he went to the local boy who charged him Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted July 8, 2006 Share Posted July 8, 2006 The tamper return from the first bell is the 0v feed on the second bell, make sure you make the 2nd Bell SCB, to prevent you from popping the fuse. If you want them on full SAB mode you will need a Larger PSU, and possibly a relay. For your situation 1 SAB and 1 SCB will be fine. Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
Service Engineer Posted July 9, 2006 Share Posted July 9, 2006 Anyway he went to the local boy who charged him ........................................................ Dave Partridge (Romec Service Engineer) Link to comment Share on other sites More sharing options...
breff Posted July 9, 2006 Share Posted July 9, 2006 Do as Watchdog says, although I have always found with Novas that even doing this when there is an activation it sends the bells into tamper. I would advise not connecting the strobe on the unit set to SCB then the only current drawn is from the 1st bell. The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment Share on other sites More sharing options...
WatchdogSecurity Posted July 9, 2006 Share Posted July 9, 2006 Do as Watchdog says, although I have always found with Novas that even doing this when there is an activation it sends the bells into tamper.I would advise not connecting the strobe on the unit set to SCB then the only current drawn is from the 1st bell. I think its something to do with bell tamper ring, if you look at the wiring diagram with the novas, they supply the hold off to the return and link to 0v or something like that, as the gartecs have this bell tamper ring facilty. Watchdog Security (Manchester) Link to comment Share on other sites More sharing options...
