Posts
11,384 -
Last visited
Days Won
162
Content Type
Profiles
Forums
Events
Downloads
Gallery
Blogs
Posts posted by PeterJames
On 18/03/2024 at 23:17, Turanafon said:
So can the siren be deleted from the panel ,
and will that stop the siren tamper or not ?
I would say it would stop the panel tamper activating but not the sounder from alarming
15 hours ago, james.wilson said:
The concern is the installer is liable if your system fails to perform.
Not only that if he tells the OP the engineers code, the the OP has the engineers code for all of his customers systems. this would leave customers vulnerable, its a bit like ford telling customers a back door into the programing of their cars can you imagine the consequences
3 hours ago, SteveDaBeard said:
Thank you James.
Do you have a favourite choice please?put a recorder in both buildings or use a ubiquity bridge
May be useful to someone that needs parts but doesnt want to go through the effort to buy a new system, but worth nothing to anyone in the industry I spend money skipping tat like that
3 hours ago, smcvey said:
hi All.
I know its an older system but Is there a way of adapting this system so I can get alerts when its activated., at moment if it goes off and I am out how do I know its been activated unless I'm home, Without subscribing to monitoring.
You used to be able to add a dialer but PSTN will be switched off soon so nobody is making them. There are GSM dialers available subscription to a mobile phone network required. You can by IP communicators but I am not sure that there are any that will allow you to diy it, and most have a subscription, the ones that are free are rubbish. As swb says if your not paying for someone to look after the server that monitors your alarm then someone is not going to look after it. There were a few free servers at one time, but every time they went down there was no rush to fix them, and most now charge for the service and to be fair they are fixed quicker. The 800l is a 30 year old panel now, maybe its time to get a proper alarm
That said that Vauxhall is probably a classic now according to Bangers and Cash.
Its a bit different with electronics though, back when the Guardall panel was new everyone had TV's with CRT tubes, and incandescent light bulbs, I cant see those becoming classics anytime soon
18 hours ago, sixwheeledbeast said:
So what happened 6 years later?
Hopefully, a stand alone fire system and not what the topic says...
TBF its only gonna be a problem if theres a fire and a fatality....
£400 seems reasonable, my tyres costs circa £300 fitted, to begin with let alone getting a new one fitted on the motorway. There is a danger value and a callout cost and a convenience factor the more I think about it the more I think its a bargain.
On 30/12/2023 at 10:44, norman said:
Not totally, remember the insurance companies lost a lot of money through covid and with weather events too.
Yeah but I feel constantly shafted Efficacy and Liability October, Fleet January, office buildings and contents February, Home insurance March, Personal vehicle insurance June. Then there is all the travel insurance when I go either on Holiday or to China on business. Ive not made a claim in years and years full ncb on the car never made a home claim, the fleet insurance is probably the only thing Ive had to claim on in the last 10 years.
HKC
in Guest Forum
2 hours ago, norman said:Erm...
Infra red radiation is anything that sends out heat - basically has a temperature above around five degrees Kelvin - gives off infrared radiation. Therefore passive infra detector is looking for heat changes, but it is also looking for motion.
DSC is no longer sold in the UK not many people here would know that panel unfortunately
HKC
in Guest Forum
11 hours ago, Terry Hunter said:At the time there was no logic I could understand, the PIR's installed at correct heights no masking, plenty of additional detection to the rear perimeter. The front of the building is a resturant and bar area so coverage by 3 pirs (not crossing each other) is enough also as it's on a high street vibration on the windows was not an option.
I can only think looking at the images the guy was totally covered up limiting the amount of IR and as the beams were set on medium sensitivity I think was the issue. When the Police arrived (called by a neighbour) everything worked as it should as they went through the door as it was not unlocked.
HKC is very good Ihave hundreds out there, but I think for me it's an eye opener as to not get too complacement with the installation and tweek the system to be more sensitive.
For information the grading for Police was mainly for the PA and the intruder was not a priority, risk assesment and specification approved by insurers and logs of testing to monitoring station all ok.
Cut and past the same stuff twice. Infra red is the detection method not what the detector is looking for, infra red detector detects heat or infra red radiation. Its unlikely that anyone can cover themselves up enough not to give off any heat at all . The ambient temp of the room versus the temp of the person. Even if the person was wearing a foil suit and giving off no heat (unlikely) he would be interrupting heat sources in the room.
I would be looking a bit closer, what happens when you set the alarm and then walk in front of detectors?
Nothing of what you have said makes any sense its almost as if your making excuses for the poor performance of your design
- 1
HKC
in Guest Forum
33 minutes ago, Terry Hunter said:Thinking of a logical answer as I think we need one -
What do you mean by we?
8 minutes ago, norman said:Yeah, check your efficacy policy.
QFA
HKC
in Guest Forum
12 hours ago, james.wilson said:It looks like pins back to front but let's see
It doesnt explain why the Police were called in the first place, however, agreed it could be a plausible explanation
HKC
in Guest Forum
Sounds a bit fishy, either someone walk tested the system and found blind spots, or the system was unset and the CCTV times have been adjusted to make it look like it was out of hours. The log logs when its armed and when its not Id be getting a print off and checking the CCTV very closely to make sure that the clocks are all correct. The only times Ive seen anything like it always turned out to be an inside job.
23 minutes ago, james.wilson said:
is chime turned on?
That would be a bit
17 hours ago, Niki1986 said:
Hi guys I have a galaxy flex panel, also have a max3 reader outdoors which is set to a sep zone that arms and disarms the alarm for our yard outside, i know I can get the ethernet module and download the gx control app, how is this set up? Would i need a static ip addess? Or is there any other way of doing this? We use a 4g sim router (tp link) as it has the best quality signal and speeds in our area. Any kind of help would be appriciated. Thanks
Hi Niki
You would probably need to get your installer to set this up for you
13 hours ago, al-yeti said:
Realistically scrap
Still better than a verisure system though
You have either pulled a wire out or not closed the tamper switch on the lid properly
12 hours ago, al-yeti said:
Recently sub says I want to change my own batteries , I said carry on , after a few weeks of continuous tamper alarm alarms because they couldn't close covers properly, they kept getting low batteries, changed battery reset keeps coming back same problem
I get this all the time, cutomers save a few quid buying their own cheaper than we can buy for. But we have to buy from a proper source, and usually if something is a lot cheaper then its for a reason. We buy batteries direct we know where they come from they are genuine and we turnover batteries very quickly so they have not been sitting around for six months. Buying from Amazon Ebay or even the bigger warehouses like B&Q you have no idea how long they have been sitting on the shelf, if the staff have recirculation the shelf. People do not realise batteries have a shelf life and that there are plenty of fake batteries out there too
Agreed with James, I too dont know ion stuff but assuming its two way wireless and lithium batteries you should get 18 months minimum. Are you able to adjust the rf poling? its the only thing that could be draining the battery, but in that case I would expect them all to be coming up low battery
you havent wired the bedroom pir up correctly if you have a tamper fault
RTU5024 GSM Gate Opener GSM Remote Switch
in !!..DIY Installers..!!
As above the relay wont have power on it, its just a switch to make the fan work you need to put power to it, but I guess this is not your objective. If you dont have a meter put one side of the fan to 0v put the other side of the fan to n/o and put 12vdc to the common then test it.
