Sl Compact Alrm User Manual
Started by
Guest_misselly_*
, Mar 05 2006 10:26 AM
11 replies to this topic
#1 Guest_misselly_*
Posted 05 March 2006 - 10:26 AM
Could anyone help please. My daughter has just moved into a new house which is fitted with an SL compact alarm. The previous owner says she has hardly ever used it, as she had a cat which kept triggering the alarm. She did not have the manual and couldn't remember how to use it. Does anybody know where I can get a copy of a user manual. Thanks[font=Arial]
#2
Posted 05 March 2006 - 12:51 PM
The Optima one in the Gallery will do..
Regards.
Regards.
#3 Guest_Phil1234_*
#4
Posted 10 April 2006 - 02:58 PM
Phil1234, on Apr 10 2006, 01:27 PM, said:
I have an SL compact and I can't find an Optima one in the gallery I can see an ADE Optima and that does not match my unit.
Please could you help direct me.
That's the one, the Optima is made by ADE. Although it's a different unit to look at the user manual is the same\similar.
#5
Posted 10 April 2006 - 04:50 PM
Is this the one?
Never wrestle with a pig, you both get covered in sh1t and the pig enjoys it!
#6
Posted 15 February 2009 - 07:43 PM
dear sir
I too have moved into a new house and it too has an sl compact alarm system .
I have had to cover all the pirs in the house too stop the alarms and was wondering if anyone can help me it is driving the naughbours mad . the previous tennent left no code for the system reset.
#7
Posted 15 February 2009 - 09:28 PM
Hi ,
if the property is rented , get the landlord to sort it , asap.
Is it making full alarm (external siren) , or is it just the chime feature (beeps from the internal speaker) , use the manual posted above to turn the chimes off.
#8
Posted 16 February 2009 - 09:13 PM
FASTCAR, on Feb 15 2009, 09:28 PM, said:
Hi ,
I own the house and have been living here for almost a year now the alarm starts with an internal warning then goes to a full outside alarm after about five mins it goes off .I also have had to cut the siren interneley as i cant stand the noise . I hope that you can assist me futher
yours Ian Derbyshire
#9
Posted 16 February 2009 - 10:48 PM
Your system needs to be defaulted to give you access to a user code , this will give you control over the system.It may be best to use the services of a local installer , ask for a default and service.
#11
Posted 01 December 2011 - 01:50 PM
hello can anyone hello i have a sl cmpact alarm system with no manual i had the power cut in the house the alarms works but there was a chime everytime the door open/ closed but this has now stopped any ideas how to reset this chime
thanks ste
thanks ste
#12
Posted 01 December 2011 - 05:19 PM
Chime > 0 > Reset. Will disable chime feature.
If you haven't had your alarm serviced in a while, I think it would be a good idea.
The alarm panel shouldn't change any programming (switch chime on), if you have a power cut.
0 user(s) are reading this topic
0 members, 0 guests, 0 anonymous users
