jackaddressable Posted March 27, 2018 Share Posted March 27, 2018 Hello, I've got a Galaxy MK7 keypad giving a keypad tamper. The tamper switch on the rear of the keypad is not being adequately pressed down by the mounting plate and accompanying tamper peg. Does anyone have any advice on a short term solution for this issue? Regards, Jack Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 27, 2018 Share Posted March 27, 2018 17 minutes ago, jackaddressable said: Hello, I've got a Galaxy MK7 keypad giving a keypad tamper. The tamper switch on the rear of the keypad is not being adequately pressed down by the mounting plate and accompanying tamper peg. Does anyone have any advice on a short term solution for this issue? Regards, Jack Long term solution piece of card inside Or make wall flat Or check wall plugs not protruding and tap them in slightly And so on Quote Link to comment Share on other sites More sharing options...
jackaddressable Posted March 27, 2018 Author Share Posted March 27, 2018 Okay, thanks. That's fine, will do. It isn't the best, but will make do. Thanks mate. Quote Link to comment Share on other sites More sharing options...
magpye Posted March 27, 2018 Share Posted March 27, 2018 Well, I've been an alarm engineer for as long as I can remember and what has been suggested, especially the first answer is the way to go. J, what do you think should be done then? Please put me and hundreds of others right then. Quote Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
PeterJames Posted March 27, 2018 Share Posted March 27, 2018 1 hour ago, magpye said: Well, I've been an alarm engineer for as long as I can remember and what has been suggested, especially the first answer is the way to go. J, what do you think should be done then? Please put me and hundreds of others right then. Calm down calm down I dont think he meant anything by it Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 28, 2018 Share Posted March 28, 2018 12 hours ago, magpye said: J, what do you think should be done then? Please put me and hundreds of others right then. What you on about dude? 12 hours ago, jackaddressable said: Okay, thanks. That's fine, will do. It isn't the best, but will make do. Thanks mate. Yes dude you are correct not the best , these keypads can be testing lol , a freshly plastered wall could still be slightly bent and cause a problem, plus customer won't always for a new keypad never really used the mk8 might be other option.... Quote Link to comment Share on other sites More sharing options...
GMill Posted March 28, 2018 Share Posted March 28, 2018 I've found the little white plugs which come with some wall sockets/switches to cover the screw hole fit nicely on that little peg Quote Link to comment Share on other sites More sharing options...
al-yeti Posted March 28, 2018 Share Posted March 28, 2018 2 hours ago, GMill said: I've found the little white plugs which come with some wall sockets/switches to cover the screw hole fit nicely on that little peg Ah good idea , you get title of clever dude Although I will look for them on ripping them out for the hkc lol Quote Link to comment Share on other sites More sharing options...
jackaddressable Posted March 28, 2018 Author Share Posted March 28, 2018 18 hours ago, magpye said: Well, I've been an alarm engineer for as long as I can remember and what has been suggested, especially the first answer is the way to go. J, what do you think should be done then? Please put me and hundreds of others right then. Honeywell should have made those tampers a bit better. From what I've seen here, quite a few have had this problem. I'm not trying to disapprove of the card method etc, I just think that it's a shame for engineers and installers alike to have such a basic problem. I'm more annoyed that there is a problem, a solution is a solution. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted March 28, 2018 Share Posted March 28, 2018 I've always broke the tab out and put a screw in the wall and adjusted as needed Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
