AM360 placement advice
Considering getting ceiling mounted 360 (AM360 DT) sensors for fresh home install (keep walls clear for wardrobes, shelves etc).
Any tips/advice on placement?
Any reason why this would not be a good idea? (ie vs traditional wall mounted)
There are windows / glass doors in most of the rooms. All rooms are ~2.4m tall. Getting cable to location is not an issue. Combined with premier elite 48 panel.
Thanks in advance for your any assistance
Link to comment
Share on other sites
Depends on the room. Corner mounted sensors are designed to cover a 90 degree area over it's detection pattern, which ideally covers across the entry points.
Positioned correctly corner mounted has better coverage IMO but there is no reason 360's couldn't be suitable.
The only time I recall using a 360 on a domestic was in a garage with no wall space anywhere.
Link to comment
Every detector will be different, generally 360's are fitted in the centre of the room but every site is different too.
Reading the detectors documentation and testing should cover everything.
Take careful note with coverage over mounting height. Keep in mind movement perpendicular to the detection pattern offers better detection.
Link to comment
