41 minutes ago, MrHappy said:
every change of tenancy requires an electrical inspection,
every cert will document the the no. of mains powered smoke detectors,
IIRC battery only complies with the some recent landlord regs but not with the building reg ?
1 hour ago, MrHappy said:
You gonna gob that big hole up which may allow a fire to penetrate the stair case ?
Good point and well spotted...
No.
The stairs are bare wood in any case just out of sight.
1 hour ago, AB 1950 said:
Thanks for the advice again but this is an existing tenant  . The smoke alarm has nowt to do with my problem although it has brought to my attention the need for a regular simple test.
Yeah, sorry and back on point...
I'd contact your landlord, he may be miffed if you start messing with fixtures and fittings albeit with good intent.
21 hours ago, norman said:
Nice link.
is this suggesting LL fit CO detectors straight away in their properties?
i still see lots with no CO detection
Edited by sjsturner
