Stevie Scott Posted January 7, 2018 Share Posted January 7, 2018 Hi folks, looking for for some guidance, decided to use our house alarm ( moved in 3 years ago already installed) found the operating instructions and detail on how to change code. When I opened the keypad door the number 9 was shown on the display panel, this I think referred to zone 9. When I pushed 9 on the keypad, the house alarm activated and the display panel went blank and wouldn’t accept any further inputs. In order to stop the alarm I had to remove the battery and disconnect mains going into main alarm box. I’m not that fussed about the alarm to be honest but just discovered the fire alarm sensors are connected to it also??? Kids in the house. when I left it fir an hour I reconnected it all back up, same issue, alarms activated, keypad not accepting any codes, though, it did flash d once then nothing.. does anyone one have any initial thoughts? many thanks, Stevie Quote Link to comment Share on other sites More sharing options...
MrHappy Posted January 7, 2018 Share Posted January 7, 2018 15 minutes ago, Stevie Scott said: does anyone one have any initial thoughts? ITS BROKEN... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Stevie Scott Posted January 7, 2018 Author Share Posted January 7, 2018 Along with my heart! Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted January 7, 2018 Share Posted January 7, 2018 I suggest you find a local installer to take a look at it. It may just require a service and possibly reprogramming but more than likely it will be recommended you replace and upgrade the system. Alternative option is to leave the system powered down and replace all your smoke detectors for stand alone battery ones. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted January 7, 2018 Share Posted January 7, 2018 Whats the age of the battery? Have you tried powering up mains only? Quote Link to comment Share on other sites More sharing options...
Stevie Scott Posted January 7, 2018 Author Share Posted January 7, 2018 4 minutes ago, PeterJames said: Whats the age of the battery? Have you tried powering up mains only? Hi Peter, battery looks to be 2003, yea tried mains only but again same issues, keypad unresponsive. 6 minutes ago, PeterJames said: Whats the age of the battery? Have you tried powering up mains only? 15 minutes ago, sixwheeledbeast said: I suggest you find a local installer to take a look at it. It may just require a service and possibly reprogramming but more than likely it will be recommended you replace and upgrade the system. Alternative option is to leave the system powered down and replace all your smoke detectors for stand alone battery ones. Thanks for the advice re smoke detectors, good idea. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted January 7, 2018 Share Posted January 7, 2018 Sounds like the panel is knackered then battery should have been replaced over ten years ago, in 2007 which is probably the reason the panel failed. As the battery dies it starts to pull more and more power, it eventually kills the charging circuit. New panel and battery, and as your bell did not ring when you down powered the panel, I would guess a new bell. Quote Link to comment Share on other sites More sharing options...
