Galaxy GX push notifications
1 hour ago, Lloydy8686 said:
Gonna try this now. Is there anything I need to know or is it simple to set up
Yes,  the selfmon keypad is much better than the Honeywell version if all you need is a remote keypad
Some instructions how to set up this on a co48 v6.8 if anyone can help. The 'panel programming' on selfmon shows options I do not have. All I want to do is receive notifications and to be able to set remotely if I forget.
Is this all possible with selfmon or would I be best just going back down the secure IP4 route to custodian and forget about this
Which options are you missing?  SelfMon also works on the older G3 panels with firmware before the Dimension was even born, so it should be working with your panel. Just let me know what's missing and I will advise.
When I'm trying to programme 'heartbeat'
 I get 'Option not available'
I'll tell you what I need and hopefully you can help me
i have a galaxy48. Brand new Ethernet module installed in it
i have BT internet so can't have a static IP so neee to use DDNS
I want to connect remotely usin the VKP and also receive push notifications
22 hours ago, GalaxyGuy said:
If the heartbeat isn't present, it doesn't matter. The important parts are the ports and message protocol. Set to UDP outgoing port 10002 and Microtech protocol.
cheers mate.  Gonna try getting this sorted tonight. Been on call or weekend so haven't had a chance
