John 4 Posted October 17, 2017 Share Posted October 17, 2017 hi , i have just cut a wire to a PIR on my alarm system........actually just knicked one of the coloured wires within cable...... the internal siren sounded and it seems all power to other PIR's and main panel has been lost ....cable wires are all connected now. any ideas .... thanks Quote Link to comment Share on other sites More sharing options...
aissecur Posted October 17, 2017 Share Posted October 17, 2017 I would suspect a fuse has blown in the panel. When was the last time the unit was serviced as this would be good time to get a professional in to give it a once over whilst hopefully repairing the system? Quote Link to comment Share on other sites More sharing options...
John 4 Posted October 17, 2017 Author Share Posted October 17, 2017 (edited) Hi yes your correct... fuse blown now it wants the engineer code which I thought was #### enter but that's not working .. so panel working but need the eng code again any ideas and thanks for reply hiw much is a service ?? Edited October 17, 2017 by sixwheeledbeast Removed code Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted October 17, 2017 Share Posted October 17, 2017 The installer would use there own code in the system. We do not give out codes, manuals or defaulting information here for security reasons. If you can't contact the original maintainer, I would recommend you call a few local companies and inquire about a service. Karisma's are quite an old panel now, I have known even well maintained ones to have iD biscuits fail and NVM issues. Quote Link to comment Share on other sites More sharing options...
John 4 Posted October 17, 2017 Author Share Posted October 17, 2017 I don't know original installer ... there must be some way of putting in a new engineer code ..... thats all it seems to need ..... anyone know how ?? Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 17, 2017 Share Posted October 17, 2017 10 minutes ago, John 4 said: I don't know original installer ... there must be some way of putting in a new engineer code ..... thats all it seems to need ..... anyone know how ?? Well you will need to default the system which may mean reprogramming it , you could pay someone to do once over and provide you with it , but if it's cost excersice then may reflect what your trying to protect meaning it's low priority Quote Link to comment Share on other sites More sharing options...
aissecur Posted October 17, 2017 Share Posted October 17, 2017 (edited) in order to change the engineer code (if unknown) it will mean a full default of the system and would require it being fully re- programmed from scratch. Unless you are fully ofay with alarms and competent I strongly suggest this is carried out by a competent alarm engineer. Edited October 17, 2017 by aissecur spelling mistake Quote Link to comment Share on other sites More sharing options...
PSE Posted October 17, 2017 Share Posted October 17, 2017 You could get someone to default the engineer & user codes only, no need for a full default. A decent alarm co / engineer could default them within no time at all. Quote Link to comment Share on other sites More sharing options...
PeterJames Posted October 17, 2017 Share Posted October 17, 2017 5 hours ago, PSE said: You could get someone to default the engineer & user codes only, no need for a full default. A decent alarm co / engineer could default them within no time at all. Are you sure? I didnt think you could with ADE panels, its been a long time since I did any programming mind. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted October 17, 2017 Share Posted October 17, 2017 Think it's a full default on these, it's the manager code you can reset via procedure , engineer is full default I believe Quote Link to comment Share on other sites More sharing options...
