HKC blocking dial capture units
jnealon
  • jnealon changed the title to HKC blocking dial capture units
12 minutes ago, datadiffusion said:
Yes, but didn't they u-turn on that?
Maybe not in Ireland
55 minutes ago, jnealon said:
Just a heads up that the the latest firmware 3.3.5 blocks a lot of dial capture units.
If the HKC panel sees anything under 30v or so you will get a line fault error. MiniAir units and their clones seem to be impacted
If it was as simple as a line voltage then surely that's to easy to bypass
Link to comment
Share on other sites
Or turn off built in LF detection I suppose as a temporary fix? Not ideal, but there are other ways to show failure / disconnection of the actual unit. Can 'line failure' also be a zone type, in order to override bell timers though?
Edited by datadiffusion
Link to comment
10 minutes ago, MrHappy said:
get it on ebay.....
data can then post a link & disapproving comments on tsi  :D
Sounds like a plan to me
7 minutes ago, james.wilson said:
if its not locked ill have it
you working on a weekend?
Isnt locked but will need defaulting
Link to comment
