MrHappy Posted August 24, 2017 Share Posted August 24, 2017 4 hours ago, installer_dale said: I'm impressed u figured out the mains cover most installers don't seem to know that or they cba there pointless & I've been chucking them for 20yrs.... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 24, 2017 Share Posted August 24, 2017 I fail to see the point of fitting a pointless piece of plastic you have to remove on each service anyway. Wouldn't bother with the screw caps either, I have seen them rounded off and jammed in before now, although this would be on the Veritas case not the Prem. Plastic caps and similar covers are just asking for screwdriver rash from numpty engineers and offer minimal aesthetics for there existence IMO. Quote Link to comment Share on other sites More sharing options...
norman Posted August 24, 2017 Share Posted August 24, 2017 We took over a company c2001 who had hundreds of Veritas out there, I had a patch with c800 contracts and used to service 2-3 daily. I never had an issue with the screw covers or mains clips, bit of a knack to removing them without trashing them I agree but I prefered the look with them Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
datadiffusion Posted August 25, 2017 Share Posted August 25, 2017 Yeah if I have to remove them, I always put them back. 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
installer_dale Posted August 26, 2017 Share Posted August 26, 2017 (edited) If panel is on show I always fit screw covers. They usually push in easily the right way round and if not a quarter turn to raise/lower them. Mains cover is in the bag so it may as well be fitted, takes 5 seconds and helps keep things safe. More of a pain to remove though. Does anyone use the battery clips? Most systems I take over have tiny 2ah or less batteries, and a bigger battery either falls out when you open the panel or its got a cable tie wrapped round it. Edited August 26, 2017 by installer_dale Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted September 11, 2017 Author Share Posted September 11, 2017 The mains cover was a pain to put on (it was a tight squeeze), but it's now there. I've installed the battery clips, but not convinced they're that effective, as the battery can still move around. Quote Link to comment Share on other sites More sharing options...
