Cluel3ss Posted August 15, 2017 Share Posted August 15, 2017 So i'm going to be doing FSL wiring, which I think is straightforward enough for the PIRs and magnetic contacts (they all come with built in resistors). But i'm not sure how I would implement it for the Texecom RKPs and Texecom telephone speech dialler? These don't appear to have any built in resisistors. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 15, 2017 Share Posted August 15, 2017 the keypad will wire into the data connections not the circuit connections Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 15, 2017 Share Posted August 15, 2017 I suggest reading the instructions for everything before you start, neither of those devices wire onto the panel as a zone. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 15, 2017 Share Posted August 15, 2017 1 hour ago, Cluel3ss said: So i'm going to be doing FSL wiring, which I think is straightforward enough for the PIRs and magnetic contacts (they all come with built in resistors). But i'm not sure how I would implement it for the Texecom RKPs and Texecom telephone speech dialler? These don't appear to have any built in resisistors. So basically the rkp, dialler, don't use eol they have there own connections as he pointed out , and swb is saying that because the manual will point this all out to you 1 Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted August 17, 2017 Author Share Posted August 17, 2017 Ok so admittedly I skimmed the manual, now its starting to make a bit more sense! Sensors go to zones, keypads to the network connections. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 17, 2017 Share Posted August 17, 2017 2 hours ago, Cluel3ss said: Ok so admittedly I skimmed the manual, now its starting to make a bit more sense! Sensors go to zones, keypads to the network connections. Don't worry I still do that , these guys constantly bailing me out dot com Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted August 22, 2017 Author Share Posted August 22, 2017 I'm currently in the process of wiring it up the sensors. In the panel there are a few accessories, one is the mains cover, the other I think are battery clips, but i'm not sure what the "toothpaste like" caps are for? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 22, 2017 Share Posted August 22, 2017 Normally the bin... However, if you would like to locate them somewhere other than your local recycling centre; they fit in the screw holes after you put the lid on. 2 Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted August 22, 2017 Author Share Posted August 22, 2017 Doh! Thanks, that didn't even occur to me, and that's even after having one of those things for the internal sounder. Quote Link to comment Share on other sites More sharing options...
installer_dale Posted August 24, 2017 Share Posted August 24, 2017 I'm impressed u figured out the mains cover most installers don't seem to know that or they cba Quote Link to comment Share on other sites More sharing options...
MrHappy Posted August 24, 2017 Share Posted August 24, 2017 4 hours ago, installer_dale said: I'm impressed u figured out the mains cover most installers don't seem to know that or they cba there pointless & I've been chucking them for 20yrs.... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 24, 2017 Share Posted August 24, 2017 I fail to see the point of fitting a pointless piece of plastic you have to remove on each service anyway. Wouldn't bother with the screw caps either, I have seen them rounded off and jammed in before now, although this would be on the Veritas case not the Prem. Plastic caps and similar covers are just asking for screwdriver rash from numpty engineers and offer minimal aesthetics for there existence IMO. Quote Link to comment Share on other sites More sharing options...
norman Posted August 24, 2017 Share Posted August 24, 2017 We took over a company c2001 who had hundreds of Veritas out there, I had a patch with c800 contracts and used to service 2-3 daily. I never had an issue with the screw covers or mains clips, bit of a knack to removing them without trashing them I agree but I prefered the look with them Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
datadiffusion Posted August 25, 2017 Share Posted August 25, 2017 Yeah if I have to remove them, I always put them back. 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
installer_dale Posted August 26, 2017 Share Posted August 26, 2017 (edited) If panel is on show I always fit screw covers. They usually push in easily the right way round and if not a quarter turn to raise/lower them. Mains cover is in the bag so it may as well be fitted, takes 5 seconds and helps keep things safe. More of a pain to remove though. Does anyone use the battery clips? Most systems I take over have tiny 2ah or less batteries, and a bigger battery either falls out when you open the panel or its got a cable tie wrapped round it. Edited August 26, 2017 by installer_dale Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted September 11, 2017 Author Share Posted September 11, 2017 The mains cover was a pain to put on (it was a tight squeeze), but it's now there. I've installed the battery clips, but not convinced they're that effective, as the battery can still move around. Quote Link to comment Share on other sites More sharing options...
