Cluel3ss Posted August 15, 2017 Share Posted August 15, 2017 So i'm going to be doing FSL wiring, which I think is straightforward enough for the PIRs and magnetic contacts (they all come with built in resistors). But i'm not sure how I would implement it for the Texecom RKPs and Texecom telephone speech dialler? These don't appear to have any built in resisistors. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted August 15, 2017 Share Posted August 15, 2017 the keypad will wire into the data connections not the circuit connections Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 15, 2017 Share Posted August 15, 2017 I suggest reading the instructions for everything before you start, neither of those devices wire onto the panel as a zone. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 15, 2017 Share Posted August 15, 2017 1 hour ago, Cluel3ss said: So i'm going to be doing FSL wiring, which I think is straightforward enough for the PIRs and magnetic contacts (they all come with built in resistors). But i'm not sure how I would implement it for the Texecom RKPs and Texecom telephone speech dialler? These don't appear to have any built in resisistors. So basically the rkp, dialler, don't use eol they have there own connections as he pointed out , and swb is saying that because the manual will point this all out to you 1 Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted August 17, 2017 Author Share Posted August 17, 2017 Ok so admittedly I skimmed the manual, now its starting to make a bit more sense! Sensors go to zones, keypads to the network connections. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted August 17, 2017 Share Posted August 17, 2017 2 hours ago, Cluel3ss said: Ok so admittedly I skimmed the manual, now its starting to make a bit more sense! Sensors go to zones, keypads to the network connections. Don't worry I still do that , these guys constantly bailing me out dot com Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted August 22, 2017 Author Share Posted August 22, 2017 I'm currently in the process of wiring it up the sensors. In the panel there are a few accessories, one is the mains cover, the other I think are battery clips, but i'm not sure what the "toothpaste like" caps are for? Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted August 22, 2017 Share Posted August 22, 2017 Normally the bin... However, if you would like to locate them somewhere other than your local recycling centre; they fit in the screw holes after you put the lid on. 2 Quote Link to comment Share on other sites More sharing options...
Cluel3ss Posted August 22, 2017 Author Share Posted August 22, 2017 Doh! Thanks, that didn't even occur to me, and that's even after having one of those things for the internal sounder. Quote Link to comment Share on other sites More sharing options...
installer_dale Posted August 24, 2017 Share Posted August 24, 2017 I'm impressed u figured out the mains cover most installers don't seem to know that or they cba Quote Link to comment Share on other sites More sharing options...
