Unable to disarm DSC PC1832 via delay zone, system goes into alarm
Hi, I am installing a DSC PowerSeries PC1832 panel and having trouble disarming.
With the alarm set, when I enter via a delay zone I am unable to disarm the system with the user code. After the delay the alarm enters the alarm state, at which point I am able to stop the alarm with the user code.
I have recorded a video showing the problem:
https://www.youtube.com/watch?v=uQ8TNsOddEM
1. Arm with code
2. Exit via delay zone
3. System arms
4. Enter via delay zone
5. System starts entry delay
6. Enter user code - Alarm does not disarm
7. Alarm sounds after delay ends
8. Enter user code during alarm
9. System disarms with alarm occurred report
If I enter an incorrect code the screen tells me this.
I have tried setting up a an additional user code, but the same issue occurs whether trying to disarm with the master code or the additional user code.
If I arm the system, I am able to disarm with the code if the delay zone is not tripped:
https://www.youtube.com/watch?v=0cClUyXIbmo
It's a DSC PC1832
Have tried the entry/exit zone set to type 01 (delay 01) and 34 (final door set)
I’m using DEOL setup.
The door contact sensor has a built in resistor at 4.7k, not the 5.6k as provided by DSC – but it senses open/close fine, and tamper is not triggered, no system troubles showing.
There is only this (1) zone connected to the system for testing, as zone 09 (zone 1 on the first PC5108 card)
All other 32 zones are set to 00 null.
There is one keypad and two PC5108 cards installed.
Thanks for your help, as I am gutted to be stumped this early on in the install and testing!
Set to prox on entry ?
So look for option in police options maybe that's the problem
Actually I mis read what you said lol it's only the delay zone you have problem with
In the UK it is Police Policy that monitored alarms  can only be set to use fobs for disarming, you are not allowed to use codes unless you use a shunt lock. But I note that you are not in the UK so therefore the rules would be different.
AlYeti assumed that you may have programmed your alarm to UK Police Policy.
We would not be familiar with the rules of your country but they may be similar, either way it is unlikely to have the same programming as a UK system. Also DSC is not a common alarm panel in the UK only one distributor as far as I am aware.
1. Arm with code
3. System arms
It's a DSC PC1832
What happens if you enter through delay zone and then open entry zone then unsets?
Yep, that's the exact setting Yeti meant, just slightly differently described by DSC. Irregular choice for a UK panel, but better than an Accenta!
Have to say the importers webby doesn't inspire much confidence with it's 6 year old brochure...
http://www.dsc.uk.com/z23J49Km/products.php
