Help with Enforcer remote software
shaun c
Hi Guys
I've just registered as a new member. Security engineer for 15 years or so. I have juts purchased a Pyronix Enforcer Wi-Fi V10 to have a play. Has anyone used or managed to use the remote software for the PC to allow remote diagnostics etc.? Ive downloaded it from Pyronix but seems as this does support the Enforcer Panel?
Any help would be appreciated
Thanks
Shaun
Link to comment
Share on other sites
(Have not tried it with V10 but should be no different)
The Enforcer works fine with remote software InSite UK.
Are your PC & panel on the same network? could be the problem.  Have you got the cloud & IP indicators green at the bottom of software?
Link to comment
3 hours ago, shaun c said:
cheers James will look at it again just wondered if any one else had found it a little confusing to work on!
They are Real alarm men , unlikely
Link to comment
PM me your email address and I will send you access to our training videos. There's I full details on how to setup Insite with v10 enforcer.
Tip. Use roving dual then Insite works out the panel type.
Link to comment
