Texecom com wifi
Foote1234
On 04/05/2017 at 7:10 PM, Amps said:
Why did you quit buddy? Spill the beans :huh:
One of our previous engineers worked at SPE before the bankers bought them out and told me nightmare stories about the installs they had and the way they treat engineers and I had had enough of the driving and 5:30 am starts. Shame really as H&S had 4 reasonably big jobs with great customers which i will miss.
On 08/05/2017 at 6:25 PM, sixwheeledbeast said:
That's only the encryption the unit will function correctly without it. (I don't agree it should, but that's another story)
You make the app generate the key and type the Hex into Engineers Utils.
The manual refers you to the full manual to do this, I recall.
Nothing to do with encryption and i can't remember what it is now, but its a real shame that the majority of the info you have to put in never changes and could be pre programmed into the panel and you can't use wintex to do it, whats the point of panel programming software if there are aspects of it that can't be used with certain bit of ancillary kit. Texecom must be loosing sales to manufacturers products like HKC whose products just work effortlessly, also sort out your tech support 1/2 an hour on hold is unacceptable.
Well I have no idea then, I have never had any issues from following the manual for the first few and must have done 50 odd now.
Yes there's lots of menus to go through as options are all over the place, they have been added to the existing menu structure which is why it makes more sense to regular Texecom installers
The information does change depending on what ancillary kit you fit, if you always fit the same kit it would be sensible to have a profile to dump on the panel.
I don't see any reason why you can't use Wintex. The manual advises to use the keypad, possibly to avoid any misconfiguration?
Possibly. I think they hope both will clear up post V4
  • 3 months later...
2 minutes ago, Amps said:
Possibly after a firmware update.
The next firmware update is version 4.XX is it not?
I was told by Texecom the new app (which we BETA tested) would only work with the new Texecom Connect module  and was a completely new app
It was sarcasm.
