PIR's in zone 4 not working
I recently found that the keypad on my Optima XM alarm was not working. I have changed the battery and managed to get it working. After doing this I decided to do a walk test to confirm that everything was working. Everything is working except zone 4 which has a PIR on the landing and a PIR in the kitchen. The PIR's both flash when I walk past but do not trigger the alarm.
All connections appear to be OK
The system was installed by builder 20 years ago and has worked well throughout (2 new batteries)
Is it likely to be a faulty PIR?
How do I find out which one?
Thanks
Link to comment
Share on other sites
3 minutes ago, Colin53 said:
Yes it has worked for years with out any problems
so zone 4 used to indicate. When did you last walk test it succesfully
9 minutes ago, Colin53 said:
James, I assume that it has always worked since they flashed has I walked past them and the system armed etc.
I've not done a walk through test until today.
Ok id say they have never worked then.
  • Upvote 1
Link to comment
I have disconnected the landing sensor in the box and the kitchen now works.
I now have the following
Zone 1 - Front door contact sensor
Zone 2 - PIR
Zone 3 - PIR
Zone 4 - PIR
Zone 5 - 3 doors with contact sensors
Zone 6 - PIR
Unused PIR on landing
Do I have any options for landing PIR?
Link to comment
