norman Posted February 26, 2017 Share Posted February 26, 2017 On the plus side, when id does ignite when you're in bed it's under the dry wooden stairs to freedom so you'll all die together. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
PSE Posted February 26, 2017 Share Posted February 26, 2017 It's probably the original battery that's baking your power supply making it really hot. There may well be a voltage in the battery but chances are it's holding little to no Ah capacity. If it's that old it's probably broken or breaking down and pulling the life out of the power supply, hungry for the charge... but can't as it's goosed. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 26, 2017 Share Posted February 26, 2017 22 minutes ago, Gabs said: they never even use the thing. heat = energy a cheapo battery might save enough pennies to pay for itself, or do an MTA & twat if off the wall whilst your mate films it for youtube ? Quote Mr Veritas God Link to comment Share on other sites More sharing options...
Gabs Posted February 26, 2017 Author Share Posted February 26, 2017 7 minutes ago, norman said: On the plus side, when id does ignite when you're in bed it's under the dry wooden stairs to freedom so you'll all die together. Ha, how did you know it is under the stairs? All dying together because of the Paragon, has anyone ever come across a panel which has caught fire? 8 minutes ago, PSE said: It's probably the original battery that's baking your power supply making it really hot. There may well be a voltage in the battery but chances are it's holding little to no Ah capacity. If it's that old it's probably broken or breaking down and pulling the life out of the power supply, hungry for the charge... but can't as it's goosed. Well, last time we had a power cut, it lasted for the full two hours. 4 PIRs, and an SAB. 1 minute ago, MrHappy said: heat = energy a cheapo battery might save enough pennies to pay for itself, or do an MTA & **** if off the wall whilst your mate films it for youtube ? Ha, I've seen those MTA Systems videos on YouTube, funny.I didn't realise the Paragon was such a hated panel. Quote Link to comment Share on other sites More sharing options...
norman Posted February 26, 2017 Share Posted February 26, 2017 (edited) From the photo I can even tell you that standing on the street looking from the front of your home you live in the right hand house of two 1960's semi's, used to shop in Sainsbury's and are due a rewire in 8 years 6 minutes ago, Gabs said: All dying together because of the Paragon, Most engineers would see that as a benefit Edited February 26, 2017 by norman 1 Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Gabs Posted February 26, 2017 Author Share Posted February 26, 2017 (edited) 15 minutes ago, norman said: From the photo I can even tell you that standing on the street looking from the front of your home you live in the right hand house of two 1960's semi's, used to shop in Sainsbury's and are due a rewire. Most engineers would see that as a benefit Hmmmm, you were close. But the house is 30s. Yes, probably due a re-wire, and no, Morrisons, always Edited February 26, 2017 by Gabs Quote Link to comment Share on other sites More sharing options...
norman Posted February 26, 2017 Share Posted February 26, 2017 Meh 1 Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
Gabs Posted February 26, 2017 Author Share Posted February 26, 2017 3 minutes ago, norman said: Meh You were close Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted February 26, 2017 Share Posted February 26, 2017 No he wasn't, he was a s**t luser as always! 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
norman Posted February 26, 2017 Share Posted February 26, 2017 F cough. Quote Nothing is foolproof to a sufficiently talented fool. Link to comment Share on other sites More sharing options...
