Sirtoddius Posted February 16, 2017 Share Posted February 16, 2017 Afternoon guys. Was as after a little bit of help from the all knowing folks of the forum. I'm going to install some Cctv on my house and had a few questions about placement. I'm going to use Hik 4mp ip Cctv cameras and fit a Poe Hik nvr next to my router behind my TV. Would this be ok or can anyone recommend any alternatives. Also im having a problem with placement of the cameras. iv attached a picture to show where I was thinking of putting some of the cameras. 1 is to cover front of house and front door. 2 to view the drive and garage and 3 to cover side of house. Any my help ,suggestions or guidance would be much appreciated. Quote Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted February 16, 2017 Share Posted February 16, 2017 I don't like Hik, but I don't see why it wouldn't work. Hard to tell from the picture but positioning looks ok. Bear in mind the higher you go the less chance you have of getting facial images. 1 Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted February 16, 2017 Share Posted February 16, 2017 As above, high isn't usually a good thing for recognition; it's often a typical sign of a DIY domestic setup TBH. 2 1 Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
Sirtoddius Posted February 16, 2017 Author Share Posted February 16, 2017 Thanks for the reply guys. Point noted on the height. Does camera number 1 seem like a reasonable height. It's high enough that it can't be reached. I will think of alternate positions for the other two. Could maybe bring 3 down to match the height of 1 to the right of the porch to cover the drive. Sixwheeledbeast is there any other brands you recommend. I have access to trade accounts at suppliers so can get most stuff. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 16, 2017 Share Posted February 16, 2017 3 hours ago, Sirtoddius said: Afternoon guys. Was as after a little bit of help from the all knowing folks of the forum. I'm going to install some Cctv on my house and had a few questions about placement. I'm going to use Hik 4mp ip Cctv cameras and fit a Poe Hik nvr next to my router behind my TV. Would this be ok or can anyone recommend any alternatives. Also im having a problem with placement of the cameras. iv attached a picture to show where I was thinking of putting some of the cameras. 1 is to cover front of house and front door. 2 to view the drive and garage and 3 to cover side of house. Any my help ,suggestions or guidance would be much appreciated. Put four cam's high for overview wide picture and four cameras low for recognition as mentioned , and stick few more up around will look hardcore 2 1 Quote Link to comment Share on other sites More sharing options...
Sirtoddius Posted February 16, 2017 Author Share Posted February 16, 2017 15 minutes ago, al-yeti said: Put four cam's high for overview wide picture and four cameras low for recognition as mentioned , and stick few more up around will look hardcore I don't want the cameras to be obstructed by the barbed wire or manned watch tower. Do you know any good moat digging companies??? 1 Quote Link to comment Share on other sites More sharing options...
Amps Posted February 16, 2017 Share Posted February 16, 2017 The fan noise from the Nvr will drive you crazy. You won't notice it at first but overtime it will get to you. i wouldn't put it behind the Tv if I were you mate. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 16, 2017 Share Posted February 16, 2017 34 minutes ago, Sirtoddius said: I don't want the cameras to be obstructed by the barbed wire or manned watch tower. Do you know any good moat digging companies??? No need , line a bunch of London rats on leads keep them hungry Quote Link to comment Share on other sites More sharing options...
Sirtoddius Posted February 16, 2017 Author Share Posted February 16, 2017 1 hour ago, Amps said: The fan noise from the Nvr will drive you crazy. You won't notice it at first but overtime it will get to you. i wouldn't put it behind the Tv if I were you mate. mate. Did not even consider the noise of the fan. Cables run via the spare bedroom so nvr could go in there. 1 hour ago, al-yeti said: No need , line a bunch of London rats on leads keep them hungry I keep this on me at all times just in case I encounter any miscreants Quote Link to comment Share on other sites More sharing options...
james.wilson Posted February 16, 2017 Share Posted February 16, 2017 lol Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
SouthernBrad Posted February 17, 2017 Share Posted February 17, 2017 As mentioned, main points for me would be the noise from the NVR's fans and the height of the cameras. Height also for the IR range as I assume they'll be anti vandal domes. The range won't be much good by the time it reaches the floor. A metre or two lower can work wonders. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 17, 2017 Share Posted February 17, 2017 You need cameras high up aswell as low down from what seems to be the Norma , costs more of course Quote Link to comment Share on other sites More sharing options...
Amps Posted February 17, 2017 Share Posted February 17, 2017 (edited) On 17/02/2017 at 6:20 PM, al-yeti said: You need cameras high up aswell as low down from what seems to be the Norma , costs more of course Cameras need cleaning on a regular basis so access to them is very important. Best bet would to be use turret cameras as they do not attract as many spiders/cobwebs as bullets and domes. Pop down to your local Adi branch as they have a decent deal on Hikvision 4Mp turret cameras at the moment. Deal expired on 14th Edited February 20, 2017 by MrHappy Deal expired on 14th Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 17, 2017 Share Posted February 17, 2017 (edited) 51 minutes ago, Amps said: Cameras need cleaning on a regular basis so access to them is very important. Best bet would to be use turret cameras as they do not attract as many spiders/cobwebs as bullets and domes. Pop down to your local Adi branch as they have a decent deal on Hikvision 4Mp turret cameras at the moment. Deal expired on 14th Lol I was. Reading down thinking somewhere hikmission is going to be mentioned But yes cleaning needs consideration, although the most residential either don't clean at all , or use an abrasive cloth on the ceramic and wonder why it's fogged up at night , muppets Edited February 17, 2017 by MrHappy removed link Quote Link to comment Share on other sites More sharing options...
Amps Posted February 17, 2017 Share Posted February 17, 2017 (edited) 52 minutes ago, Amps said: Cameras need cleaning on a regular basis so access to them is very important. Best bet would to be use turret cameras as they do not attract as many spiders/cobwebs as bullets and domes. Pop down to your local Adi branch as they have a decent deal on Hikvision 4Mp turret cameras at the moment. Deal expired on the 14th The DS-7608NI-E2/8P/A is also a decent price @ £125.99. Check Out the online prices you wont beat that. Edited February 17, 2017 by MrHappy Quote Link to comment Share on other sites More sharing options...
al-yeti Posted February 17, 2017 Share Posted February 17, 2017 9 minutes ago, Amps said: The DS-7608NI-E2/8P/A is also a decent price @ £125.99. Check Out the online prices you wont beat that. If that's your trade price your offering public excellent 1 Quote Link to comment Share on other sites More sharing options...
Sirtoddius Posted February 20, 2017 Author Share Posted February 20, 2017 (edited) On 17/02/2017 at 9:05 PM, Amps said: Cameras need cleaning on a regular basis so access to them is very important. Best bet would to be use turret cameras as they do not attract as many spiders/cobwebs as bullets and domes. Pop down to your local Adi branch as they have a decent deal on Hikvision 4Mp turret cameras at the moment. Deal expired on 14th Yeah i I see that deal in my local gardiners security. Was the 4mp fixed lens ones and had a Hik Dvr on offer too. Would Just like to say thank you for the help from everyone. It's very much appreciated. Edited February 20, 2017 by MrHappy Deal expired on 14th Quote Link to comment Share on other sites More sharing options...
Amps Posted February 22, 2017 Share Posted February 22, 2017 On 17/02/2017 at 9:05 PM, Amps said: Cameras need cleaning on a regular basis so access to them is very important. Best bet would to be use turret cameras as they do not attract as many spiders/cobwebs as bullets and domes. Pop down to your local Adi branch as they have a decent deal on Hikvision 4Mp turret cameras at the moment. Deal expired on 14th The deal did not expire on the 14th. It is available throughout February. Only the items in the top left hand box have now expired. Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 22, 2017 Share Posted February 22, 2017 1 hour ago, Amps said: The deal did not expire on the 14th. It is available throughout February. Only the items in the top left hand box have now expired. everything on the 1st page (expect cable ties) are marked 2 weeks only & everything on the back page is marked 2 weeks only the small print says "trade only" & "subject to availability" Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted February 22, 2017 Share Posted February 22, 2017 (edited) 3 hours ago, MrHappy said: everything on the 1st page (expect cable ties) are marked 2 weeks only & everything on the back page is marked 2 weeks only the small print says "trade only" & "subject to availability" I am sure your on drugs only way you could spot half this stuff or a mutant Edited February 22, 2017 by al-yeti Quote Link to comment Share on other sites More sharing options...
datadiffusion Posted February 22, 2017 Share Posted February 22, 2017 3 hours ago, MrHappy said: the small print says "trade only" yeah, but that's a bit like the fake £1 cover price on the local estate agents magazine, or 'do not use your phone whilst driving' innit? Quote So, I've decided to take my work back underground.... to stop it falling into the wrong hands Link to comment Share on other sites More sharing options...
MrHappy Posted February 22, 2017 Share Posted February 22, 2017 5 hours ago, datadiffusion said: yeah, but that's a bit like the fake £1 cover price on the local estate agents magazine, or 'do not use your phone whilst driving' innit? IIRC having a "free mag" with price printed on the front is about claiming back tax rather than expecting payment... Quote Mr Veritas God Link to comment Share on other sites More sharing options...
MrHappy Posted February 22, 2017 Share Posted February 22, 2017 6 hours ago, al-yeti said: I am sure your on drugs only way you could spot half this stuff or a mutant you seen the flyer ? there's a bosch g2 pir which is 31p cheaper than SW with a minimum order of 6, wow £1.80 odd saved Quote Mr Veritas God Link to comment Share on other sites More sharing options...
al-yeti Posted February 22, 2017 Share Posted February 22, 2017 Plus postage more expensive ? Quote Link to comment Share on other sites More sharing options...
MrHappy Posted February 22, 2017 Share Posted February 22, 2017 ADI, Enterprise & SW do me free shipping on a minium spend Quote Mr Veritas God Link to comment Share on other sites More sharing options...
