DanTheManUK Posted January 17, 2017 Share Posted January 17, 2017 I have a Honeywell Optima alarm panel, with seperate Led Keypad. One morning in the early hours my son (half asleep) mistakenly identified the kitchen clock radio blaring as an alarm activation. During his attempt to shut down the alarm (which was not even sounding - actually the kitchen radio was sounding) he entered programming mode and has inadvertently affected the alarm settings. Now PIR no3 is permanently on alert. This PIR is located on upstairs landing. Whenever anyone passes in front of this PIR the alarm immediately activates. Even if the system is in Day mode it activates an alarm. When the system is part set during the day to outbuildings, this PIR activates the alarm. When the system is part set at night, this PIR activates the alarm. and so on....... Currently when selecting a part set I have to omit zone 3. Also I cannot leave it in Day mode, I have to select a part set and then omit all zones. Very frustrating. I contacted Honeywell for telephone support, in the past they have assisted me in resolving a different issue & testing the system. However now they inform me they no longer provide telephone support for this. Apparently they only support thermostat systems ? So I'm here again, hat in hand lol Would greatly appreciate any advice or assistance you guys can provide. P.S I have the manual downloaded already, but I struggle to follow it. I am good with instructions normally - but these manuals seem to speak a different language altogether... Dan. Quote Link to comment Share on other sites More sharing options...
al-yeti Posted January 17, 2017 Share Posted January 17, 2017 (edited) I would say you have entered the engineer code and changed the zone attribute to 24hr or PA or something , link it out in the pir until either you learn to programme it or get an engineer to put it right Although some one could probably tell you to do it here , or just put a link across the pir alarm terminals as you can't use the system anyway The gsm unit below should not need to be messed with PS I hate that manual to lol Edited January 17, 2017 by al-yeti Quote Link to comment Share on other sites More sharing options...
james.wilson Posted January 17, 2017 Share Posted January 17, 2017 when you say the alarm activates when in day mode its not as simple as chime has been turned on for that circuit. Don't think you can program that panel much its an old sl Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
andy™ Posted January 17, 2017 Share Posted January 17, 2017 when you say ' the alarm immediately activates' do you mean actually sounds as in bellbox blaring and code needing entered, or most likely, as james said, a small noise which is the chime which just needs turned off... common issue, been called to that many times.... iirc, on that panel you press chime, press the number light thats lit to take it off then press either reset or chime again (cant remember which) Quote Link to comment Share on other sites More sharing options...
DanTheManUK Posted January 17, 2017 Author Share Posted January 17, 2017 (edited) Al-yeti I'm hoping someone here will be able to instruct me... lets see in the mean time I will continue to omit that zone in all instances. andy - now you ask I will need to walk test it to remind myself exactly what it does. Had so much noise from the thing the last few weeks I'm not entirely sure anymore. i think from memory, wether the system is FULL SET, PART SET or in DAY mode, if you approach this particular PIR the panel begins to beep asking for the code (similar to when setting the alarm on exit or entry) however no one is ready to react at the panel so we almost always end up with sirens blaring a few moments later. So its basically acting as a SET BUTTON (make sense?) i will run a walk test to confirm all of the above and re-post though... also I will look into the chime suggestion from James & yourself. Edited January 17, 2017 by DanTheManUK Quote Link to comment Share on other sites More sharing options...
PSE Posted January 18, 2017 Share Posted January 18, 2017 Try this, You will need your engineer code PROG. (Eng Code) 5 3 Look at the led that's lit up These are your zone 3 Attribute options 1 - Security 2 - Fire 3 - 24 Hour Fire 4 - Push to Set 5 - Keyswitch Check what yours is, maybe set to 3 or 4 by accident, hence always activating. Change the option as above, hear a beep as confirmation and reset all way back out. Quote Link to comment Share on other sites More sharing options...
DanTheManUK Posted January 18, 2017 Author Share Posted January 18, 2017 To confirm the above, I've PART SET the system. Approached PIR 3 (should not be active in the part set) and the speaker started to chirp, as if entry activated. I switched off at panel. Also in DAY MODE this PIR behaves in exact same fashion. PSE - I've followed your instruction to identify attribute for Zone 3. Led 1. was illuminated. According to your key, this is security ? I think I need an engineer familiar and knowledgable with this panel to reprogram my system. Unless I can get Honeywell to provide telephone support and talk me through the re-programming. I did call them a couple weeks ago, at this time they advised me they no longer provide telephone support for these systems (which I find disappointing) Any further suggestions / views welcome. Quote Link to comment Share on other sites More sharing options...
andy™ Posted January 18, 2017 Share Posted January 18, 2017 odd... if its unset then it shouldnt activate entry timer at all. if it was a 24 hour fire zone then you wouldnt get an entry timer either, it would go straight to alarm you could try changing the setting in 5 3 to 0 (disabled) and see what happens Quote Link to comment Share on other sites More sharing options...
DanTheManUK Posted January 25, 2017 Author Share Posted January 25, 2017 UPDATE I finally managed to get Honeywell Tech support to speak with me. We went through some investigations in prog mode. Discovered the problematic zone was programmed as 'Key Switch' now its disabled from this function it is behaving normally again. (( I don't know what the function of 'Key Switch' is normally - can anyone tell me? )) During diagnostics I also discovered 2 further zone programming errors, Zones 2&3 were Entry (should be alarm) and Zones 5&6 were inhibit (should be alarm). All reprogrammed correctly now. Thank you to forum members again for your input & suggestions. P.S you should know, despite not being in the industry I find the topics you cover & discuss very interesting, great approach by your members. Makes good reading.. Quote Link to comment Share on other sites More sharing options...
PSE Posted January 25, 2017 Share Posted January 25, 2017 On 18/01/2017 at 6:38 PM, DanTheManUK said: PSE - I've followed your instruction to identify attribute for Zone 3. Led 1. was illuminated. According to your key, this is security 2 hours ago, DanTheManUK said: Discovered the problematic zone was programmed as 'Key Switch' now its disabled from this function it is behaving normally again. Im assuming you didn't check this then ? Quote Link to comment Share on other sites More sharing options...
