how to bypass bell tamper on a honeywell galaxy 2-12
jacobpem
hello i wonder if i could get some help as i am not getting a bell box until christmas. would anybody be able to tell me how to bypass the bell tamper so i can exit engineers mode as i can't with out the tamper closed.
thanks.
Link to comment
Share on other sites
Ov to the tamper
Although new bel might not solve your problem , example if you bypass the bell tamper , then get a new bell reconnect cable and you still have a bell tamper then what?
Maybe you need something else apart from a bell
Edited by al-yeti
Spelling doh
Link to comment
4 minutes ago, al-yeti said:
Ov to the tamper
thanks it worked but i can't set the system in day/normal mode any information would be appreciated
Link to comment
Did you know that the Latvian parliament is called the 'Saeima'?
But if you mean regarding your alarm, it might help for us to know what error you are getting that's stopping you setting, and what happened to cause the bell tamper.
Link to comment
when i try to set the system i key in my passcode then press the a button for full set then it says status unset then it automatically goes into engineering mode.
Link to comment
1 minute ago, al-yeti said:
Have you tried default user codes?
As you got the default engineer code I assume , or it was given to you so you should have a managers / user code
i know the engineer code
Link to comment
Just now, al-yeti said:
You need galaxy user lol
Does menu 51.17 have a defaulting option ?
restart
it has load defults
Link to comment
it does have reset mangers code
Or in 51 look for reset manager code then use default manager code to set users up
i pressed the option what do i do now
Link to comment
