Abacus system TRBL POWER fault
Titch007
Hi all,
Another issue with my alarm. On searching on the forum, I understand that a TRBL POWER fault on the DA system Abacus is due to a faulty battery. Just wondering if I remove the cover to find out what battery to get, will all hell break lose? I've not reset the system or set it as I fear the internal sounder will just go off for hours. I just moved into this property and been left with no manuals etc. I have no engineer codes either, just the master code.
I'm assuming that if I undo the cover on the box, a tamper fault will register. Do I just switch the battery and reset the system with the master code? Or is this a job for the professionals? Any advice will be greatly appreciated.
thanks in advance,
Titch
2 hours ago, Titch007 said:
Hi all,
thanks in advance,
Titch
Trbl Power is also the message for AC fail. Try to set the system with the master code then unset the system and if it is AC failure and the AC has restored the panel will be reset.
Thanks for the responses guys.
So I'll definitely need a engineer code to change the battery even though I have the master?
I managed to download a copy of the Abacus manual and it said if it was an AC fault the code TRBL SUPPLY. I reset the system. The TRBL power code disappeared but after 5mins the interval bell went off again with the same fault code.
The box is metal. Has anyone got any idea which battery is standard or best?
Im sure it says trbl mains if its mains
What you mean interval bell?
You mean it just started beeping on internal speaker with the high tone?
That will be the battery
You got nothing to lose , just put new battery in , if it's engineer reset you will have to call someone out , ask them to make it user reset
