Neil Jones Posted January 23, 2016 Share Posted January 23, 2016 Just wanting to check my wiring understanding for the Galaxy Flex 50 with the AG8 Sounder as the manual for both the panel and the sounder is a little confusing. The Flex PCB has the following output connections: 1 2 3 T 0V Based on the manual for the sounder I believe I need to connect: TR- (neg tamper return) to T V- (negative supply) to 0V ST- (neg. strobe trigger) to [OP]2 which I believe is default programmed as STROBE S- (neg. sounder trigger) to [OP]1 which I believe is default programmed as BELLS V+ (positive) I am assuming I can use any +12V connector, e.g one of the three +12V connections from the zones? I have to admit it is the V+ that has bothered me.. as most panels Ive seen has a +12V BELL connector alongside the other bell connections.. but +12v is +12v right...? I don't have an internal speaker, so assume don't have need for the third output. I notice that there are "pull up links" in place for OPs 1-3, what do these do? I assuming I don't need to touch these? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted January 23, 2016 Share Posted January 23, 2016 pull up is resistive pull up for logic etc, but the sink is neg. Yes id say your right Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
Neil Jones Posted January 23, 2016 Author Share Posted January 23, 2016 Thanks for the swift reply, looks like a quick test before getting the ladders out tomorrow morning! It was the +12v that bothered me most.. also forgot to ask.. I don't need an EOL resistor in the sounder do I? Quote Link to comment Share on other sites More sharing options...
Dklemm Posted May 24, 2017 Share Posted May 24, 2017 Sorry to drag this post up, I was looking to ask exactly the same question. The installation instructions vs the actual terminals for wiring are poor, especially given you have OP1, OP2, OP3, T, V- but no V+. Where do you take the V+ for the output from? Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted May 24, 2017 Share Posted May 24, 2017 Any of the +12V connections, but probably neater to select the one on the vertical block to the left of the bell connections. They are all connected to the same copper and poly fuse on the board. Quote Link to comment Share on other sites More sharing options...
Dklemm Posted May 24, 2017 Share Posted May 24, 2017 Thanks for the fast reply. I just read another post of your recommendating the Odyssey over AG do you still recommend? Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 25, 2017 Share Posted May 25, 2017 no its a Texecom unit Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
GalaxyGuy Posted May 25, 2017 Share Posted May 25, 2017 Yes, the Honeywell sounders are too quiet. Even the single piezo Texecom unit is much louder on the wall. Quote Link to comment Share on other sites More sharing options...
james.wilson Posted May 25, 2017 Share Posted May 25, 2017 in my tests the tone of the cqr unit was loudest imo Quote securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
sixwheeledbeast Posted May 26, 2017 Share Posted May 26, 2017 Opinion? Surely tests are definitive? In an industry of self certification do we think the manufacturer specs are best to compare the loudness? AG6 110dB@1m Ody Single Piezo 109dB@1m CQR Multibox 115dB@1m Deltabell 104dB@1m These are likely to be peak values and consider the tone, frequency and mounting surface will make a difference to overall volume. Whatever flashing, glowing and noisy piece of plastic you put on the front of your building, it's likely to do it's job if wired correctly. 1 Quote Link to comment Share on other sites More sharing options...
GalaxyGuy Posted June 12, 2017 Share Posted June 12, 2017 Used the newer Texe X-B dual piezo sounders at the weekend. Think I'll be using/recommending them from now on. Not sure about the test results above - the AG6 must have been tested without the cover on... Quote Link to comment Share on other sites More sharing options...
