Fused Spurs
Kate Scorey
Working live isn't illegal, but for the sake of not turning off a server may be frowned upon. Best way imo is leave the spur to the customer.
As far as I understand from a 'justifiable' point of view, the HSE regard live working as acceptable only in the absence of any realistic alternative.
So if you are live working on a fuseboard that is fitted with multiple means of safe isolation, but you don't want to use them 'to avoid pissing off the client' and work live, this would not sit well.
For suppliers who have no alternative but to cut into live cables, then of course there isn't a practical alternative.
Re modifying a circuit without an rcd, are you sure about that?
I am sure thats what i got told, ?? am i wrong ??
I was told I was not allowed to add a fuse connection unit to a circuit with not RCD.
I can see if i can find the info
Probably in case any part of the circuit is buried beneath plaster.
Originally said by Charles Babbage
On two occasions I have been asked [by members of Parliament], 'Pray, Mr. Babbage, if you put into the machine wrong figures, will the right answers come out?' I am not able rightly to apprehend the kind of confusion of ideas that could provoke such a question.
There is no need to 'retrospectively' work to the 17th if, say, you are in a house done to the 15th, 16th etc...
A case in point is fusewire type consumer units. The Electrical Safety Council (formerly part of NICEIC) are at pains
to point out in a dedicated leaflet that this does NOT mean an installation fails a PITS / EICR just for having one.
Oh ok
BUT it must still be compliant. So if the existing installation is unsafe, you can't add to it.
A classic example is a house with rubber cabling still (very unlikely to see these days)
but there were a few still around when Part P first came in and although we probably would
have offered a rewire or walked anyway, with Part P you had to say 'no' even if it was just a spur etc...
Another good example would be the one I found the other day with everything quite tidy but NO main earth!
Edited by datadiffusion
  • 2 weeks later...
