May 24, 201313 yr comment_322890 Guys, Got hold of an Eco4 as part of an upgrade. Needs a new fan (which dont cost much) but I was hoping to knock it on afterwards. I obviously dont want to sell it with a hard drive full of images. Is there a way of defaulting the hard drive from the DVR? I have done a reset from the menus but that only seems to default programming. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr comment_322892 Easiest way is put it on its highest record setting, attach a camera, loop the output of cam1 to cam2 and cam 2 to cam3 etc, point the camera at the wall and leave it recording until it fills up The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322892 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr Author comment_322895 I did think about doing it this way, or leave it powered up with no camera connected so that it records a black screen for a couple of weeks. Assuming that the older ones record with no camera inputs? Edited May 24, 201313 yr by timmo66 Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322895 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr comment_322898 Remove hdd, formatt in normal pc. Reconnect and the dvr should re formatt the hdd when it boots up. Is there not a reinlitilize option on those ? Should be an option to format the hdd Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322898 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr Author comment_322902 Is there not a reinlitilize option on those ? Should be an option to format the hdd This is what I was hoping for, but I couldnt see anything within the DVR menus to format the drive Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322902 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr comment_322911 Just had a look at the manual. No format options. Either take the hdd out and format. Or record a blank screen for a few weeks. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322911 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr comment_322912 Remove hdd, formatt in normal pc. Reconnect and the dvr should re formatt the hdd when it boots. This will not completely remove the images. I'd either use a killdisc like program in a desktop or record nothing on highest frame rate for a while like above. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322912 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 24, 201313 yr comment_322944 im fairly sure the os is on the drive so I wouldn't format it. securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-322944 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 25, 201313 yr comment_323066 Do not format the drive, the OS is on it as James says The opinions I express are mine and are usually correct! (Except when I'm wrong)(which I'm not) Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-323066 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 25, 201313 yr Author comment_323125 second thoughts, the DVR may be more use to me than the pennies that they fetch for second hand. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34617-dm-eco4-defaulting-hard-drive/#findComment-323125 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
