May 17, 201313 yr comment_321244 HiI have a flex 20 panel with a strange error. (Not sure what it is). Panel is bought and installed by me, I don´t have a service contract. I´m using RF units only. It has been working perfectly until now (or stil is except the error). My main door with a magnetic contact (DO800M) is programmed as Part-Final zone. When I set the system (full or part doesn´t matter) the panel displays 1021 Entré (which is my main door)Whith the choices [esc] to cancel and [enter] to override. If I override the system sets and everything is fine. I´ve triggered the system via the main door and it works. Nothing shows up in the log and the magnetic contact seems to work. Any idéa why I recieve this error (or warning rather...)? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr comment_321270 If you enter your code and select Display->Zones->1021 What does the zone information give ? Press '#' and what info is displayed ? Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321270 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr comment_321271 Need more detail about the error. What is logged securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321271 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr Author comment_321272 Display Zone gives me 1021 Closed/Open (woorking fine) RF105Sig09Lo03 Can´t fins anything about it in the logs, displayed as a normal set operation. The exact info displayd when setting (part or full) is 1021 Part-Final Esc to cancel, Ent to override Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321272 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr comment_321274 what happens when you put in your manager code and press ent? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321274 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr Author comment_321281 Thank you for the reply Nothing, I just need to press enter when the message appears and the system sets as usual. (with a user code or by using a keyfob) I have aloso tried the manager code to set the system and the result is the same: 1021 Part-Final........... When I exit engineer mode everything looks fine, no tamper warnings or anything like that. I bit annoying as the keyfob more or less become obsolete because I stil nedd to press a key [ent] to set. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321281 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr comment_321282 Sounds like it has an un acknowledged alert from tgst cercuit. Try a 51,17 reboot the panel securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321282 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr Author comment_321283 Did a reboot and ended up with a system error message so something must have gone terribly wrong. Just did a cold start......So back to programming again Thanks for all the help guys! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321283 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 17, 201313 yr comment_321289 You might have had corruption in the memory then securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/34563-galaxy-flex-20-strange-errorwarning/#findComment-321289 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
