Texecom Bell Box
Guest james callaghan
Hi, just set up veritas R8 system, when carried out a part set and activated the system, then performed a reset the External Sounder/Bell box still activated and can't turn off. Checked wiring at both sides both ok. Any ideas? Many thanks
Its either wired incorrectly or a faulty bell how have you wired it i.e. what terminal bell to what terminal panel?
Of course it may be a panel fault is the panel still outputing once you have reset? and lastly make sure the strobe output is not in anyway connected or shorted with the bell trigger
