July 13, 201015 yr comment_245451 Hello there, I have a versatillity system that is not releasing line one after a call has finished. Anybody got any idea's about how to fix it? scratchhead Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29343-bt-versatillity/ Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 13, 201015 yr comment_245470 We had a similar issue on a revelation. It was to do with line voltage. There was bb on the line and we had to replace the filter. Do you have anything else on that line and if you swap the lines around does this issue move? securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29343-bt-versatillity/#findComment-245470 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 201015 yr comment_247259 Your problem is with Guarded clear lines the cleardown time needs to be adjusted you can get BT to do it from the exchange or if you have version 4 ovide software you can do it your self should be set from 500milisec upto 1000. blue Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29343-bt-versatillity/#findComment-247259 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 29, 201015 yr comment_247281 Your problem is with Guarded clear lines the cleardown time needs to be adjusted you can get BT to do it from the exchange or if you have version 4 ovide software you can do it your self should be set from 500milisec upto 1000. blue would this happen on an established system? i wonder if L1 is reversed, that i know upsets Panasonic PABX's Arfur If you think education is difficult, try being stupid!!!! Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29343-bt-versatillity/#findComment-247281 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
July 30, 201015 yr comment_247315 you can set the line to loop ungarded and that will clear the hung line problem but you will lose other facilities ie; Trunk to trunk transfer and speedail use. best to get the clear down time checked. This can start happening on an old system if any routine maintainance has been carried out by BT in the exchange a line reversal will not cause this problem. I had this problem a lot when i have installed this system in a residentual or home business and bt don't realise the lines are going on a telephone system. Blue Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29343-bt-versatillity/#findComment-247315 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
May 8, 201115 yr comment_273163 I use to work for bt, and there is no difference in a business line or residential in the volts present and ringing etc. so what difference does it make if you have a residential line or business when ordering. Link to comment https://www.thesecurityinstaller.co.uk/community/topic/29343-bt-versatillity/#findComment-273163 Share on other sites Share on LinkedIn Share on X Share on Facebook {lang="reddit_text" Share via email Share on Pinterest More sharing options... Share this post
