FishpondsLad Posted May 29, 2009 Share Posted May 29, 2009 Looking for some help here if anyone has a free moment. The cover on the Concept intruder alarm sound box was accidentally knocked off last night. The keypad accepted the code to stop the alarm going off, but then went into tamper mode and won't accept any further codes - no beep when the keys are pressed. The Tamper and Power lights are on, the infra red detectors are working and the alarm bell sounds when the mains is turned off - but I can't reset the key pad or enter any numbers. If anyone has any ideas I would be most grateful. Thanks. Link to comment Share on other sites More sharing options...
james.wilson Posted May 29, 2009 Share Posted May 29, 2009 you still have the tamoer fault then. Until the fault is restored and reset it wont do anything. James securitywarehouse Security Supplies from Security Warehouse Trade Members please contact us for your TSI vetted trade discount. Link to comment Share on other sites More sharing options...
lawandorder Posted May 29, 2009 Share Posted May 29, 2009 you still have the tamoer fault then. Until the fault is restored and reset it wont do anything.James QFA Whatever caused the tamper (the sound box being knocked) needs putting back properly beofre the tamper will clear. There is probably a tamper switch on the box which isn't getting pressed properly. Sort that out then press the reset button. Link to comment Share on other sites More sharing options...
FishpondsLad Posted May 29, 2009 Author Share Posted May 29, 2009 QFAWhatever caused the tamper (the sound box being knocked) needs putting back properly beofre the tamper will clear. There is probably a tamper switch on the box which isn't getting pressed properly. Sort that out then press the reset button. Thanks to Redbull and Lawandorder for your quick responses. I've had a look in the sound box to check for a reset button but the only thing that seems to fit the bill is a small white button. When pressed this sets off the alarm but when that's turned off with the override code the tamper light stays on. The reset button needs to be reset, but I can't see how to do it for it doesn't seem to match up with a pressure point and there is no spring. Sorry, still stumped! Link to comment Share on other sites More sharing options...
hpotter Posted May 29, 2009 Share Posted May 29, 2009 If the external sounder goes when the mains is off, your control panel bettery needs replacing. Also reckon your panel has "locked out" due to all the twoing & throwing, again, due to the system not being serviced ie, battery needs changing. Link to comment Share on other sites More sharing options...
antinode Posted May 29, 2009 Share Posted May 29, 2009 Thanks to Redbull and Lawandorder for your quick responses.I've had a look in the sound box to check for a reset button but the only thing that seems to fit the bill is a small white button. When pressed this sets off the alarm but when that's turned off with the override code the tamper light stays on. The reset button needs to be reset, but I can't see how to do it for it doesn't seem to match up with a pressure point and there is no spring. Sorry, still stumped! These panels will appear to "lock up" if there is an outstanding tamper fault, which you have. There should be a spring on the small white button which will make contact with the rear of the keypad when it's assembled. Without it, you won't be able to clear the fault. Once it's been replaced and put back together you will be able to reset the fault. Trade Member Link to comment Share on other sites More sharing options...
magpye Posted May 29, 2009 Share Posted May 29, 2009 Thanks to Redbull and Lawandorder for your quick responses.I've had a look in the sound box to check for a reset button but the only thing that seems to fit the bill is a small white button. When pressed this sets off the alarm but when that's turned off with the override code the tamper light stays on. The reset button needs to be reset, but I can't see how to do it for it doesn't seem to match up with a pressure point and there is no spring. Sorry, still stumped! This should help, a drawing of a, cover removed, Concept KeyPad Someone told me I was ignorant and apathetic, I don't know what that means, nor do I care. Link to comment Share on other sites More sharing options...
lawandorder Posted May 29, 2009 Share Posted May 29, 2009 Looking for some help here if anyone has a free moment.The cover on the Concept intruder alarm sound box was accidentally knocked off last night. The keypad accepted the code to stop the alarm going off, but then went into tamper mode and won't accept any further codes - no beep when the keys are pressed. The Tamper and Power lights are on, the infra red detectors are working and the alarm bell sounds when the mains is turned off - but I can't reset the key pad or enter any numbers. If anyone has any ideas I would be most grateful. Thanks. Can you post a picture of the "sound box" or do you know what make and/or model it is? Link to comment Share on other sites More sharing options...
antinode Posted May 29, 2009 Share Posted May 29, 2009 Edit: Cocked up there. Meant to say sounder instead of keypad in my original post. Trade Member Link to comment Share on other sites More sharing options...
FishpondsLad Posted May 30, 2009 Author Share Posted May 30, 2009 Problem sorted! Many thanks to all for taking time to help - much appreciated. Link to comment Share on other sites More sharing options...
