Menvier Fire Panel Ax1
Guest trickey
Guest trickey
hi
can any body help iam looking for a manual for the above it addressable type control panel i need to loop learn devices etc
many thank trickey
Link to comment
Share on other sites
hi
many thank trickey
You have a problem there. The AX1 uses the old Menvier 600 series detector with addressable base but I have added i maybe 2 devices of the newer 700 series addressable detector. Can be a problem I did have a manual somewhere but cannot lay my hands on it at the moment. :angry2:
Peter Robinson
Freelance
M:07889038650
Link to comment
Guest jonnymac101
tricky .... if ure adding new devices ont the system and youve not had a chip upgrade it wont accept the new devices ... you can buy a new chip for about 300 quid (rip off ) BUT THJATS BIG COMPANYS FOR YA
Link to comment
  • 1 month later...
hi
many thank trickey
Hello,i am an ex menvier engineer,you dont need a manual they are really easy to use,if you want to add new devices(700 series)which are a problem to get hold of,you will nee
to upgrade panel software.The chip you need is called a poo chip!no im not joking!menvier
will charge you
Link to comment
hi
many thank trickey
will charge you
Link to comment
How about adding text ???
And what about defender panels, can these be added to/maintained ?
its an old beast you want text its either a marker pen or a label printer job ;) . the front controls have 2 x 7 segment leds on them. I you've seen a Tan fire one its the same sort of set up.
I'am sure menvier don't sell the software to anyone but may have "agents"
Link to comment
god the trusty defender the one u cant isolate loop sounders on (amazing technology :-| )
All comments in this post are my own views and do not necessarily reflect the views of my employer
Link to comment
Link to comment
